Using Raspberry Pie As ChromeCast
Postby wmhafiz » Mon Apr 09, 2018 3:09 pm
Hi
I'm new with Adurino & Raspberry Pie but really interested to learn the technology.
Found this tutorial :
HOW TO USE RASPBERRY PI AS CHROMECAST
Would like to try the tutorial. Equipment needed is raspberry Pi 3 .
I try to search Raspberry Pi 3 on Cytron portal
Cytron - Raspberry Pi Board
Which one is recommended if i want to order it from Cytron portal?
wmhafiz
Re: Using Raspberry Pie As ChromeCast
Postby Idris » Mon Apr 09, 2018 3:30 pm
Hi wmhafiz,
The tutorial link that you provide uses Raspberry Pi 3 - Model B (1GB RAM).
Thanks. :)
Postby wmhafiz » Mon Apr 09, 2018 4:21 pm
Hi Mr Idris
Thanks for your fast respond
Looks like Raspberry Pi 3 Model B+ will available soon at Cytron.
Just add-on RM3 will get better spec
I think i will go for the latest model Raspberry Pi 3 Model B+
Is it ok to do the chromecast project using different model compare to The tutorial link
wmhafiz
Postby Idris » Tue Apr 10, 2018 1:32 pm
Hi wmhafiz,
We're not sure when Raspberri Pi 3B+ will be available in our store. If it is not urgent, you can wait. Else you can consider to use Raspberry Pi 3 first. :)
Return to Misc Project
