Final Year Project for Computer Engineering
Postby nazfar » Tue Nov 29, 2011 1:43 pm
Good days, I have some problems about my final year project. My FYP is about Application of RFID in Supply Chain. I'm quite new here. I need your advice which best components of that I have to choose to build and RFID?
Secondly, I still cannot find any solutions to integrate the RFID to Database in purpose of tracking the history about the products in supply chain such as time, product code, type of product, status and so on.
I really hope that you guys can help me. :(
nazfar
Re: Final Year Project for Computer Engineering
Postby low5545 » Tue Nov 29, 2011 2:20 pm
Do you want to connect the RFID to the computer, go for this (http://www.cytron.com.my/viewProduct.php?pcode=RFID-IDR-232N&name=RFID%20Reader%20RS232%20(New)). You'll need a RS232 to TTL converter (can be made using a MAX232 circuit - http://www.facebook.com/l.php?u=http%3A%2F%2Fjason.mumby.co.nz%2Fwp-content%2Fuploads%2F2010%2F03%2Fpiffo77_1112975528_piffo77_max232.gif&h=LAQGKoAdLAQFunGzL0u8yQSxaeIHJ9fkKDUX4I3zHwSDLmg) and a USB to UART converter (http://www.cytron.com.my/viewProduct.php?pcode=UC00B&name=USB%20to%20UART%20converter%20V2011 or http://www.cytron.com.my/viewProduct.php?pcode=UC00A&name=USB%20to%20UART%20Converter) to connect it to the USB port. If your computer has a Serial port at the back, you can save money and just make connection through the DB9 connector. You can also construct a GUI yourself. Check out their detailed desription (http://www.cytron.com.my/usr_attachment/RFID-IDR-232N_User's_Manual.pdf) Hope this helps.
low5545
Postby nazfar » Wed Nov 30, 2011 12:53 am
Thank you. I much appreciate it :) . By the way, i need to make little enhancement about my project such as its capability in terms of functions as my lecturer said. Any suggestions? :?
nazfar
Postby zhenning » Wed Nov 30, 2011 10:20 am
nazfar WROTE:Thank you. I much appreciate it :) . By the way, i need to make little enhancement about my project such as its capability in terms of functions as my lecturer said. Any suggestions? :?
Make sure you have your basic things working first. Then, only start to think of improvements. If your improvement methods failed, at least you will have something to present =)
zhenning
Postby nazfar » Fri Dec 02, 2011 2:43 pm
I need your advise about my project. DB9 is hardly found on nowadays especially while connect to the PC. Perhaps it can replaced with USB. If can, what is the method? Or using RJ45 and use another device to support? Currently I am on progress in developing the database for the project. The scope is in warehouse where the RFID track and trace stock in and out and I add on some tracing on expiry date of the product and which shelf its located in warehouse. Please guys help me :cry: :cry: :cry:
nazfar
Postby yonghui » Fri Dec 02, 2011 4:23 pm
u can get uc00A
http://cytron.com.my/viewProduct.php?pc ... 0Converter
or uc00B
http://cytron.com.my/viewProduct.php?pc ... er%20V2011
for the serial communcation which it emulate a com port
Postby nazfar » Fri Dec 02, 2011 7:21 pm
Active X Data Object. Is it the right choice for me to integrate R.F.I.D. with Database? Any opinions from you guys? Now I'm using Visual Basic for developing the GUI and M.S Access for the database. Hopefully you guys can help me? I'm very new here. :(
nazfar
Postby jenshen418 » Sat Dec 03, 2011 1:58 pm
Do u guys know how to connect RFID with PLC? and do u guys know where gt sell USB RFID??
jenshen418
Postby nazfar » Sat Dec 03, 2011 2:38 pm
jenshen418 WROTE:Do u guys know how to connect RFID with PLC? and do u guys know where gt sell USB RFID??
visit this website http://www.cytron.com.my/viewProduct.php?pcode=UC00B&name=USB%20to%20UART%20converter%20V2011 and this http://www.cytron.com.my/viewProduct.php?pcode=UC00A&name=USB%20to%20UART%20Converter
nazfar
Postby robosang » Sat Dec 03, 2011 8:11 pm
Not really know about that, sorry, cannot help much! 8-)
Return to Misc Project
