Please help, NOoB here!
Postby mazlano27 » Tue Mar 27, 2012 10:07 pm
So what i need, is to build a robot, that can carry a load, maximum 500g (which would mean i would need strong motor/gears system) through a path that is not straight, with obstacles. Ideally the path of the robot should be pre-programmable. What would i have to buy to make this robot? Including the equipment needed to program the micro-controller.
And how should i go about programming the micro-controller?
mazlano27
Re: Please help, NOoB here!
Postby Idris » Tue Mar 27, 2012 10:20 pm
mazlano27 WROTE:So what i need, is to build a robot, that can carry a load, maximum 500g (which would mean i would need strong motor/gears system) through a path that is not straight, with obstacles. Ideally the path of the robot should be pre-programmable. What would i have to buy to make this robot? Including the equipment needed to program the micro-controller.
1. Can carry 500g
2. Avoid obstacles?
Actually what is the application of this robot?
Can try Mini Mobile Robot Controller.
Postby mazlano27 » Tue Mar 27, 2012 10:40 pm
there is no actual point to this robot, its a project for my engineering course. And i have taken a look at the MC40A that you specified. I dont know what i have to you that component in accordance with.
To make it clear, i have to build a robot, that has to travel around obstacleus, pass a softball around 300g max to another device. Im taking it one step at a time, the first step is moving the ball to the bucket.
mazlano27
Return to Misc Project
