Automatic Clothesline Retrieval System
Postby huntersouls » Wed Sep 26, 2012 9:52 pm
I need some help on choosing light and rain sensor for this project, any recommend sensor? :D
Thank You~~~
huntersouls
Re: Automatic Clothesline Retrieval System
Postby yonghui » Wed Sep 26, 2012 10:55 pm
light sensor, mayb u can start by using LDR.
Postby ABSF » Thu Sep 27, 2012 8:21 am
You can make your own rain sensor using a small piece of stripboard as link attached:
http://www.escol.com.my/kits/ES-010.html
Postby huntersouls » Sat Sep 29, 2012 9:33 am
yonghui WROTE:light sensor, mayb u can start by using LDR.
Okay.... but how the sensitivity of this LDR? As when weather is raining sometimes there is still have light?
huntersouls
Postby huntersouls » Sat Sep 29, 2012 9:35 am
ABSF WROTE:You can make your own rain sensor using a small piece of stripboard as link attached:
Thanks for the suggestion, i try before this water sensor but it need some amount of water to detect as i consider one element which is when there is rain but not raining cat and dog but with small rain sometimes it cant detect. Is there any suggestion for more sensitive sensor?
huntersouls
Postby yonghui » Sat Sep 29, 2012 5:21 pm
i think u will need combination of sensors output to determine whether it is real rain or not. sometime, its raining but the sky still seems to be very clear.
Postby huntersouls » Mon Oct 01, 2012 8:43 pm
yonghui WROTE:i think u will need combination of sensors output to determine whether it is real rain or not. sometime, its raining but the sky still seems to be very clear.
I got find few but this device consists with wind turbine.... which i dont need the wind detect function..is there any good suggestion?
huntersouls
Postby has_mmu » Fri Dec 28, 2012 11:01 am
Maybe this is the same project.
I used large strip board to detect really rain. :idea:
http://8051fordummies.blogspot.com/2012/01/automatic-cloths-lines-pic-based.html
has_mmu
Return to Misc Project
