Re: Attendance system
Posted: Sun Dec 16, 2012 5:20 pm
There is highly likely no need for a driver in linux for USB. It has been prebuild in the kernel itself. Did you manage to see UC00B in you linux terminal?
zhenning WROTE:There is highly likely no need for a driver in linux for USB. It has been prebuild in the kernel itself. Did you manage to see UC00B in you linux terminal?
Marvin_G WROTE:zhenning WROTE:There is highly likely no need for a driver in linux for USB. It has been prebuild in the kernel itself. Did you manage to see UC00B in you linux terminal?
i tried this command "dmesg | grep tty" (not really sure what it means) and it said that pl2303 converter iw now attached to ttyUSB0. is it useful?
zhenning WROTE:Marvin_G WROTE:zhenning WROTE:There is highly likely no need for a driver in linux for USB. It has been prebuild in the kernel itself. Did you manage to see UC00B in you linux terminal?
So,it is recognized. What are you trying to do by just sending 0xF5?
Marvin_G WROTE:do i really need to put the "" thing when writing the command to the device?
zhenning WROTE:Marvin_G WROTE:do i really need to put the "" thing when writing the command to the device?
Yes you need that. What are you trying to do first? I believe there is one row of commands rather than just 0xF5?
gadgetng WROTE:Try see what is the response after you giving the command. Maybe you can have some clue from them.
