Color LCD project
Thu Mar 13, 2014 10:50 pm
by wilson
I am planning to do some GUI using PIC32 with TFT LCD, anyone have suggestion?
I have found a source with video from
http://www.lelong.com.my/tft-lcd-module ... Sale-P.htmBut it is using STM32. Is PIC32 sufficient to draw LCD?
Thanks for help.
Re: Color LCD project
Sat Mar 15, 2014 8:50 am
by takao21203
Sure it is but use a PIC with a larger FLASH- 128K or more.
Because number of instructions = FLASH kbytes/4.
The 80MHz PICs are very fast actually.
Sat Mar 15, 2014 9:50 am
by wilson
takao21203 WROTE:Sure it is but use a PIC with a larger FLASH- 128K or more.
But Stm32F4 series is up to 180MHz
my worry is refreshing color LCD will be slow and reduce response. Thanks.
Sat Mar 15, 2014 11:05 am
by takao21203
I would worry about that at all. What do you want to display?
Sat Mar 15, 2014 11:12 am
by wilson
I want to use color lcd to display text that received from Bluetooth, meanwhile, also need to draw a graphics meter to represent angle sensor position, that mean, when angle change, meter will move.
Sat Mar 15, 2014 11:43 am
by Brian Griffin
Do you have the datasheet for the LCD? These LCDs often contain a "Vertical Sync" pulse pin, so you can update the frame (display) by microcontroller everytime the Vertical Sync pin is up.
For a lot more speed, you have to use the DMA (Direct Memory Access) modules in the ARM/PIC32 processors. The DMA streams (moves) blocks of data without CPU intervention into the GPIOs where these will be connected to the data lines for the LCD.
Mon Mar 17, 2014 11:57 pm
by wilson
Thanks for your suggestion. I have datasheet, but not familiar with DMA anyway i will try.
