Phone apps and wireless components communication
Postby kelvin8686 » Fri Jul 31, 2015 7:04 pm
Hi Cytron Team,
Kindly need some advise from yours site, Below some queries stated:-
1. What phone apps suitable to interface with electronic component wirelessly such as arduino? My concern is Analog input which means i input text A, 8x-LED Display A and not via the Phone>PC>arduino. Just the Phone direct to arduino and display result.
2. What electronic component is relevant to interface with phone apps? Kindly provide Model. Exp: Arduino Uno..
3. Do i need a modem/router transmit or receive data?
Wish to hear from your soon..
Thank you..
kelvin8686
Re: Phone apps and wireless components communication
Postby ober » Sat Aug 01, 2015 10:35 pm
1. The common one is to use Bluetooth or WiFi for wireless. Bluetooth you can try Arduino BT joystick Free or BlueTerm. WiFi you can try WiFly Remote. You must develop something around the apps and Arduino, develop code for it. Or at least find tutorial regarding it.
2. Obviously, Arduino UNO or other compatible controller, LEDs, resistors, Bluetooth module, WiFi module, shield, etc. The list goes on. We can only give example, all projects are different when you go detailed, and only by doing it you will know exactly what is needed.
3. Well, that depends on the wireless technologies, and module. Bluetooth is point to point, no modem is needed. WiFi, depends, If you are using XBee-WiFi, it support soft AP, no router is needed.
You will have to do some study, I am sure there are more questions. Answering those question is copying the text book about wireless and electronics and paste here.
Postby Idris » Sun Aug 02, 2015 10:39 pm
Hi kelvin8686, you can refer to our tutorial related on Android smartphone apps and microcontroller.
Remote Mobile Robot with XBee-WiFi (Android)
Connect Android Bluetooth to BlueBee
Postby kelvin8686 » Mon Aug 03, 2015 11:28 am
Dear all,
thanks for information. :)
Another queries is the Text input with the phone apps and activate LED is depend on the program of apps right? :?:
kelvin8686
Postby Idris » Mon Aug 03, 2015 12:06 pm
kelvin8686 wrote:Dear all,
It depends on the apps and program on the microcontroller. And make sure the electronic part is working too.
Postby kelvin8686 » Wed Aug 05, 2015 12:58 pm
Hi Idris,
It can be consider serial communication as my required? Refer link below:
https://hcgilje.wordpress.com/2010/02/1 ... unication/
kelvin8686
Postby ober » Fri Aug 07, 2015 10:05 am
If you plan to do wired interface, the IOIO is the right choice for Android phone. But you need to use iphone, the link you shared would be a good reference.
Postby kelvin8686 » Tue Oct 06, 2015 2:33 pm
Hi Cytron Team,
Which Brushless DC motor(without gear) I should use for my project in order to fulfil the motor speed:1800 rpm, torque: 3kg-cm? My project need carry 3kg electronic components and spin in maintain speed and without noise condition. :?: :?: :?: :?:
kelvin8686
Return to Misc Project
