Autonomous Boat-waypoints via GPS
Postby shi kuan » Fri Oct 09, 2015 9:39 pm
Hello!
I want to build autonomous boat, controlled by waypoints via GPS.
http://users.libero.it/riccardo.rocca/0 ... t2011.html
Some questions:
1. Its possible to build the boat using Cytron product?
2. If so,what is the necessary product to be considered. I have purchased GSM modem and still wondering if it is applicable.
3. Maybe there is a ready-made solution?
Best regards
shi kuan
Re: Autonomous Boat-waypoints via GPS
Postby ober » Sat Oct 10, 2015 10:29 pm
The link is broken, at least for me, I cannot see the page.
We do not have the material to build the boat, but I guess the controller and other electronics stuff is usable.
You need to list out the parts that you want, it is easier for us to recommend.
Postby shi kuan » Sun Oct 11, 2015 12:28 pm
Screenshot of the content :
I have made a collision avoidance system with simple ready-made code. What i did was using a ultrasonic sensor that switches off one of two dc motor so that it can steer away from floating object. Now i'm thinking of giving it a way-point to head to and return to its original. It also can return to its original position when battery is running low.
This is the link that inspired me.
https://www.youtube.com/watch?v=aCiyorya53g
The component inside that boat:
shi kuan
Postby shi kuan » Sun Oct 11, 2015 12:32 pm
The code:
code.zip
not really understand the code, so i have doubt whether it is applicable in my case
(6.42 KiB) Downloaded 231 times
Schematic diagram:
Roboat_2011.zip
(48.12 KiB) Downloaded 223 times
Best regards.
shi kuan
Postby shi kuan » Mon Oct 12, 2015 2:50 pm
Do check this link
minddump.us/projects/arduino-autopilot-rc-boat/
It other boat via gps navigation but with different configuration
shi kuan
Postby ober » Wed Oct 21, 2015 8:19 am
It is not possible for us to go through all the codes :)
But I guess you can utilize some of Cytron stuff and building it will need your effort.
- Promini
- Digital compass
- XBee PRO series 1
- SKGPS
- MD30C or MDD10A depending on the motor current.
- DC motor, full range is here.
- Li-po battery
It is not direct replacement, that is why you need to try it out.
Return to Misc Project
