what digital pin is the jack connected to?
Postby mahyuddin chan » Tue Jan 30, 2018 5:35 pm
hi im trying to figure out what digital pin is the jack using, or is there a function that can be used so that
if i were to upload toneMelody (from the examples) it will play from the speaker instead of digital pin 8 (interestingly DP8 is not written in as output pin...)
anyway for now what i have done is i have hot wire DP8 to the tip of the jack, so it will play from the speaker.
mahyuddin chan
Re: what digital pin is the jack connected to?
Postby ober » Thu Feb 01, 2018 10:18 am
Not really understand which Jack you are referring to... Can you explain with example of product or picture?
Postby Idris » Thu Feb 01, 2018 12:40 pm
Hi mahyuddin chan,
I'm assuming you are talking about Maker Uno. Piezo buzzer inside Maker Uno is connected to pin 8 through slide switch beside it.
Return to Misc Project
