Hot Air blower and temperature sensor
If you have any suggestion or proposal that would like to share with us, please post it here. Thanks.
Postby ganicus » Tue May 08, 2012 6:09 am
I want to control the hot air blower which can be controlled through some script like perl. There should be a temperature sensor as well to sense the temperature. So that depending upon the temperature I can change the flow of the hot air.
Please help me regarding this project. What components will be required.
Thanks
ganicus
Re: Hot Air blower and temperature sensor
Postby royalstorm7 » Tue May 08, 2012 7:37 am
Hi ganicus..
it can be done by regulates the Fan speed using PWM relative to the temperature or u can use servo mechanisme to control a damper while fan speed are constant....or u can regulate both...!
roslan
royalstorm7@yahoo.com
royalstorm7
Return to Ideas for New Products
