Mini 2-wheels self-balancing robot
Postby fkwl » Tue May 01, 2012 4:41 pm
Description: This is a small 2-wheels robotic project. I learnt most of the algorithms from the Segwii project (http://www.segwii.com). The inertia measurement unit (IMU) and the geared motors are sourced from Cytron itself. The 'complementary filter' approach is used to combine the signals from the accelerometer and gyroscope.
Microcontroller: Microchip's dsPIC33F128GP204
Language: C
Compiler: MPLAB C30
IMU: 5-axis (3 for accelerometer, 2 for gyroscope), I use the SN-IMU5D from Cytron. Actually only 1 axis each is used for the accelerometer and gyroscope.
Battery: 7.4V 1000mA/hour Lithium Polymer
Motor: 150:1 micro-metal geared motor. Initially I used Cytron's SPG10-150K, later I switch to the high-power (HP) version from Pololu.
Motor Driver: Standard H-bridge
Video: http://www.youtube.com/watch?v=LJTW1lulGBY
The front view. The 'head' contains 2 infrared (IR) sensors.
The side view, the IMU module is clearly visible on the top.
fkwl
Re: Mini 2-wheels self-balancing robot
Postby choyhong88 » Tue May 15, 2012 3:28 pm
i am using dspic30f4013, may u share your source code, i m stuck with the coding...
thank in advance
choyhong88
Postby fkwl » Sun May 20, 2012 3:06 pm
Sorry not convenient to share the source codes for now. A proprietary RTOS is used for the project, with the balancing and motor control processes running on top of it. Try to read the article by Shane Colton of MIT, it should help.
http://web.mit.edu/scolton/www/filter.pdf
fkwl
