Simple LFR PID using PICBasic Pro
Postby holy_rainman » Thu May 03, 2012 9:05 pm
Project Name: Simple LFR PID using PICBasic Pro
Author/Designer: holy_rainman
Project Description:
To implement classic PID control algorithm to the Line Following Robot using Basic Language. The sensors used are from CYTRON SN-IRS-02 (thanks for the cute sensor) and are processed using analogue method. The motor driver used are L293D + micrometal gearmotor 30:1 which are common in mobile robot . I made the PCB board stacked together cause it gives a compact image towards the robot. I put on a common LCD to scroll the menu and to ease the troubleshooting process. The hardware cost around RM 250.
Photo/Picture/Figure/Diagram/Flowchart:
The LFR:
PCB Top 1:
PCB Top 2:
PCB Bottom 1:
PCB Bottom 2:
The video:
Compiler: PICBasic Pro 2.46
Source code: Basic Language
Schematics & PCB Docs:
PCB Top:
PCB Bottom:
Programing:
Refer file as per attached.
PID LFR.rar
PID LFR
(2.05 KiB) Downloaded 308 times
holy_rainman
Re: Simple LFR PID using PICBasic Pro
Postby holy_rainman » Thu May 03, 2012 10:30 pm
fyi, the robot move kinda sluggish because i post the non optimum value of pid at that time. The optimum value of Kp, Ki,and Kd needs to be tuned in order to have a good output. 1,1,7 at maximum battery of 7.4V
holy_rainman
Postby ABSF » Fri May 04, 2012 12:25 am
I love your PCB design - very beautiful, neat and tidy. Are all the holes plated through?
Postby holy_rainman » Fri May 04, 2012 9:14 am
thanks allen, however the holes are not plated :( i have to solder a wire to get the top and bottom a connection.
holy_rainman
