Simple wireless sensor network test bed using SKXbee
Postby mohamad_taib » Sun May 13, 2012 5:24 pm
Project Name: simple wireless sensor network test bed using SKXbee
Author/Designer: Mohamad Taib bin Miskon
Project Description:
Remote sensor nodes will sample the temperature and humidity using 10 bit conversion and send the data through wireless link to coordinator to be interpreted in more readable form. this project consist of 1 coordinator and 2 end device or sensor mote.
coordinator consist of
- 1 arduino board + xbee pro module + xbee shield
sensor motes consist of :
SKXbee + temperature sensor + humidity sensor
Data packets were sent to coordinator in API frame format.
Photo :
Compiler: Arduino + XCTU
Source code:
sample program as follows:
this source code seems messy as many unnecessary lines still there
#include <NewSoftSerial.h>
NewSoftSerial xbeeSerial(2, 3);
byte packet[40]; //guess array size bigger than necessary
int i = 0;
int num = 0;
int count = 1;
int idx = 0;
int dataArray[5][5];
long tlong;
long tlong2;
long tlong3;
long tlong4;
int dg1,dg2,dg3,dg4;
int d1,d2,d3,d4;
int dc1,dc2,dc3,dc4;
unsigned long start, time, elapsed,minit,hour;
Serial.println("waiting for packets...");
Serial.println("time: 0:0:0,");
// set the data rate for the NewSoftSerial port
xbeeSerial.begin(9600);
void loop() // run over and over again
//get all the bytes in one RF packet
while(xbeeSerial.available()) {
packet[i] = xbeeSerial.read();
num = i+1; //num is the number of bytes in the RF packet
i++;
delay(1); //a little delay is necessary at 9600 baud rate
if(i>0){//Only want to print it once!
Serial.println();
timer();
printit();
fillDataArray();
empty_packet(num);
void printit(){
Serial.print("sample number :");
Serial.println(count);
Serial.print("Receive packet from mote Address :");
Serial.print(packet[4],HEX);
Serial.println(packet[5],HEX);
Serial.print("number of RF packet bytes = ");
Serial.println(num);
for(int j=0; j<num; j++){
Serial.print(packet[j],HEX);
Serial.print(", ");
Serial.println();
i =0; //reset counter wait for next RF packet
count++;
//num = 0;
void fillDataArray(){
       Serial.print("RSSI : -");
       Serial.println(packet[6],DEC);
        dataArray[0][0] = packet[11]*256 + packet[12];
        Serial.print("Voltage reading from temperature sensor :");
       tlong = (long)dataArray[0][0]*3000;
       tlong = tlong/1023;
       dg1 = tlong/1000;
       Serial.print(dg1);
       Serial.print(".");
       dg2 = (tlong/100)%10;
       Serial.print(dg2);
       dg3 = (tlong/10)%10;
       Serial.print(dg3);
       dg4 = tlong%10;
       Serial.print(dg4);
       Serial.print("V");
       Serial.println();
       tlong2 = (long)dataArray[0][0]*350; //205 utk full range dari -55C-150C
       tlong2 = tlong2/1023;  //26
       Serial.print(tlong2);
       Serial.print("degree");
       Serial.println();
     if (num>14)
        dataArray[0][1] = packet[13]*256 + packet[14];//packet 13 utk MSB , packet 14 utk LSB
         Serial.print("Voltage reading from Humidity sensor :");
       tlong3 = (long)dataArray[0][1]*3000;
       tlong3 = tlong3/1023;
       d1 = tlong3/1000;
       Serial.print(d1);
       Serial.print(".");
       d2 = (tlong3/100)%10;
       Serial.print(d2);
       d3 = (tlong3/10)%10;
       Serial.print(d3);
       d4 = tlong3%10;
       Serial.print(d4);
       Serial.print("V");
       Serial.println();
       tlong4 = (long)dataArray[0][1]*80; //Relative humidity range 10% to 90%
       tlong4 = tlong4/1023;
       Serial.print(tlong4);
       Serial.println("%RH");
  Serial.println();
  dg1 = 0;
   dg2 = 0;
  dg3 = 0;
  dg4 = 0;
  tlong2 =0;
   d1 = 0;
   d2 = 0;
  d3 = 0;
  d4 = 0;
  tlong3 =0;
  tlong4 =0;
void timer()
Serial.print("time: ");
start = millis();
hour = (start/3600000)%24;  //sec
Serial.print(hour);
Serial.print(":");
minit = (start/60000)%60;
Serial.print(minit);
Serial.print(":");
time = (start/1000)%60;   //hour
Serial.print(time);
Serial.println(",");
void empty_packet(int n)
 for (int m=0;m<n;m++)
    packet[m] = 0;
Till then.. have fun!
mohamad_taib
Re: Simple wireless sensor network test bed using SKXbee
Postby ober » Tue May 15, 2012 4:27 pm
Nice work! Thanks for sharing it!
Postby kl84 » Fri Jun 01, 2012 12:58 pm
How do you connect all three XBee together? Mess network? I only used one pair of XBee before :P
kl84
Postby mohamad_taib » Mon Jun 04, 2012 10:18 am
hi there,
sorry for the late reply,
i'm using star topology, we can set all remote node to send data to the same destination address which is the coordinator address. we can create mesh network using xbee series 2.
mohamad_taib
