PCB Program
Questions related to PCBs design
PCB Program
Postby TeoYX » Wed Sep 14, 2011 6:13 pm
Hi all,
Anyone familiar with Eagle software (PCB Schematic Layout program)? Do you know what is the symbol for the battery holder?
Hope somebody can help on this. Thanks a lot in advance.
From,
Teo YX
TeoYX
Re: PCB Program
Postby hyng » Thu Sep 15, 2011 3:27 pm
Sorry.. nvr use b4. But i found one of the thousands tutorial in website..
http://www.sparkfun.com/tutorials/108
Hope it will help u. ;)
Re: PCB Program
Postby TeoYX » Fri Sep 16, 2011 9:17 am
OK, thanks.
Does anyone know how to do this too? Hope can get some suggestions. Thanks a lot.
TeoYX
Re: PCB Program
Postby Brian Griffin » Fri Sep 16, 2011 11:45 am
I have used a bit. Have you checked the Instructables tutorial? They have a couple of tutorials of designing PCB using Eagle. :)
Re: PCB Program
Postby TeoYX » Sun Sep 18, 2011 8:41 am
Hi all,
ya, i also found the tutorials, however, there is no library for that? Does anyone have the Eagle library for the "adapter socket" and "push button switch"?
Please help if you know where to download or if you have, please pm to me, i will provide you my email.
Thanks a lot.
From,
Teo
TeoYX
Re: PCB Program
Postby sich » Mon Sep 19, 2011 1:46 pm
Hi Teo,
I've created a new forum for "PCB Design" and your post has been removed to this forum.
About your question, you can search for Sparkfun's Eagle library online. They open the library for download somewhere out there. The components you want should be available in their library. Have a try.
Re: PCB Program
Postby TeoYX » Mon Sep 19, 2011 10:14 pm
ok, i will go there to try it. Thanks a lot.
TeoYX
Re: PCB Program
Postby TeoYX » Fri Sep 30, 2011 12:17 am
I am using the PR25 and doing the PCB schematic diagram. However, i found that there is no symbol for Push Button from the library which you recommended. It is 2 pins only. Does anyone know the symbol for Push Button? If yes, can send me this part library only?
Hope can get your help. Thanks a lot.
TeoYX
Re: PCB Program
Postby zhenning » Fri Sep 30, 2011 3:45 pm
Grab the sparkfun library and add it to the eagle libraries:
http://www.opencircuits.com/SFE_Footprint_Library_Eagle
it will add more footprint and symbols. Most likely you would find the one you need here :)
zhenning
Re: PCB Program
Postby TeoYX » Fri Sep 30, 2011 5:18 pm
Hi, I already downloaded this library but don't have this symbol for 2 pins push button. Did you get this symbol? if yes, can teach me how to add this?
Thanks a lot.
TeoYX
Return to PCB Design
