PCB Program
Questions related to PCBs design
Re: PCB Program
Postby ober » Sat Oct 01, 2011 11:13 am
TeoYX WROTE:Hi, I already downloaded this library but don't have this symbol for 2 pins push button. Did you get this symbol? if yes, can teach me how to add this?
Maybe you could create your own library for 2 pin push button? We are not familiar Eagle so cannot help much, sorry about that. 8-)
Re: PCB Program
Postby TeoYX » Sat Oct 01, 2011 11:31 am
Do you know how to create own library? I still new in this software. If any experienced person know how to do, can please tell me?
Hope for your kindly help. Thanks a lot.
TeoYX
Re: PCB Program
Postby zhenning » Sat Oct 01, 2011 1:04 pm
Hi
I will need the details for the switch the best is if there is any datasheet.
zhenning
Re: PCB Program
Postby TeoYX » Sat Oct 01, 2011 5:20 pm
zhenning WROTE:Hi
Here is the component but don't have data sheet:
http://www.cytron.com.my/viewProduct.ph ... 202%20Pins
and
http://www.cytron.com.my/viewProduct.ph ... h%28PCB%29
can you please teach me how to create own library for these items?
TeoYX
Re: PCB Program
Postby zhenning » Sat Oct 01, 2011 10:36 pm
the 2nd switch you can just replace them with header pins, it should fit :)
zhenning
Re: PCB Program
Postby zhenning » Sat Oct 01, 2011 11:07 pm
Since
ramaking 2010-10-11 06:47:53
what is dimension between leg..can mount into pcb?
Admin Reply :
Hi, the leg distance is 200mil (5.08mm). is can fit into standard strip board.
Then, you should be able to use header to represent it too. Unless you want the trouble to create them XD :)
zhenning
Re: PCB Program
Postby TeoYX » Thu Oct 06, 2011 1:00 am
hehe, i still don't know how to create own library. Do you have this library for the 2 pin button already? Can please send one copy for me?
TeoYX
Re: PCB Program
Postby zhenning » Thu Oct 06, 2011 1:35 pm
TeoYX WROTE:hehe, i still don't know how to create own library. Do you have this library for the 2 pin button already? Can please send one copy for me?
Try this out. Not sure if its right as i dont have the full dimension except the distance between the pins :)
SW_2.rar
(989 Bytes) Downloaded 469 times
zhenning
Re: PCB Program
Postby TeoYX » Fri Oct 14, 2011 12:37 am
Thanks zhenning.
TeoYX
Re: PCB Program
Postby zhenning » Fri Oct 14, 2011 10:01 pm
TeoYX WROTE:Thanks zhenning.
Welcome
zhenning
PreviousNext
Return to PCB Design
