difference with Surface Mounted Device and Double Sided pcb
Questions related to PCBs design
Postby vitor85 » Mon Jul 23, 2012 7:19 am
can you let me know what difference with Surface Mounted Device and Double Sided pcb!thank you!
vitor85
Re: difference with Surface Mounted Device and Double Sided
Postby zhenning » Mon Jul 23, 2012 8:56 am
You are trying to compare SMD and PCB? Doesnt really making any sense. I guess you want to know what are both of them?
zhenning
Postby yonghui » Mon Jul 23, 2012 11:19 am
surface mount component are components mounted to pcb on surface. double layer pcb is pcb with both surfaces have routing
Postby vitor85 » Mon Jul 23, 2012 9:15 pm
do you have any detail information ?thank you!
vitor85
Postby robosang » Tue Jul 24, 2012 9:38 am
Google it 8-)
Postby zhenning » Wed Jul 25, 2012 8:04 am
Integrated circuit SMD packages
SOIC - Small Outline Integrated Circuit. This has a dual in line configuration and gull wing leads with a pin spacing of 1.27 mm
TSOP - Thin Small Outline Package. This package is thinner than the SOIC and has a smaller pin spacing of 0.5 mm
SSOP - Shrink Small Outline Package. This has a pin spacing of 0.635 mm
TSSOP - Thin Shrink Small Outline Package.
PLCC - Plastic Leaded Chip Carrier. This type of package is square and uses J-lead pins with a spacing of 1.27 mm
QSOP - Quarter-size Small Outline Package. It has a pin spacing of 0.635 mm
VSOP - Very Small Outline Package. This is smaller than the QSOP and has pin spacing of 0.4, 0.5, or 0.65 mm.
LQFP - Low profile Quad Flat Pack. This package has pins on all four sides. Pin spacing varies according to the IC, but the height is 1.4 mm.
PQFP - Plastic Quad Flat Pack. A square plastic package with equal number of gull wing style pins on each side. Typically narrow spacing and often 44 or more pins. Normally used for VLSI circuits.
CQFP - Ceramic Quad Flat Pack. A ceramic version of the PQFP.
TQFP - Thin Quad Flat Pack. A thin version of the PQFP.
BGA - Ball Grid Array. A package that uses pads underneath the package to make contact wit the printed circuit board. Before soldering the pads appear as solder balls, giving rise to the name. By placing the pads underneath the package there is more room for them, thereby overcoming some of the problems of the very thin leads required for the quad flat packs. The ball spacing on BGAs is typically 1.27 mm.
zhenning
Postby vitor85 » Wed Jul 25, 2012 9:08 pm
for double sided circuit???
vitor85
Postby zhenning » Wed Jul 25, 2012 11:05 pm
What are the details you are searching for? I believe yonghui has explained it?
zhenning
Postby vitor85 » Thu Jul 26, 2012 7:29 am
can give more information for this 2 type PCb!thank you!
vitor85
Postby zhenning » Thu Jul 26, 2012 11:14 am
vitor85 WROTE:can give more information for this 2 type PCb!thank you!
There is only one type of PCB you have mentioned here, which, is double sided PCB.
zhenning
Return to PCB Design
