Arduino and sensor libraries for Eagle
Questions related to PCBs design
Postby tan tai pinn » Fri Feb 21, 2014 12:26 pm
Hi, I would like to know if it is possible to get the libraries in Eagle for the components bought from Cytron. I would only want the dimensions of the drilling holes so that I can drill the acrylic sheet accurately to attach the Arduino and other sensors bought from Cytron, namely the IMU and infrared sensor. Or is there any other software where there are available libraries? Thank you very much this is for my FYP.
tan tai pinn
Re: Arduino and sensor libraries for Eagle
Postby yonghui » Fri Feb 21, 2014 2:18 pm
i think cytron did not provide eagle footprint. but i think most product has the dimension specifications in the user manual or dedicated dimension document to show the accurate information for the footprint. You can draw your footprint according to the document. for the IR sensor, if it is 5mm IR i think the footprint should be same as 5mm normal LED.
Postby tan tai pinn » Mon Feb 24, 2014 11:36 am
Thank you for your reply! have a nice day!! :D
tan tai pinn
Return to PCB Design
