PCB design for Xbee Module & Breakout board and UC00B
Questions related to PCBs design
Postby dhivya » Mon Jun 23, 2014 10:52 am
Hi Im new in PCB design. I want to use Xbee module and connect it to the computer via UC00B. How should my design be? Can i solder the Xbee breakout board on my PCB and still connect to UC00B?
dhivya
Re: PCB design for Xbee Module & Breakout board and UC00B
Postby ober » Tue Jun 24, 2014 8:58 am
Yes, you can solder the XBee Breakout board, just be careful as once you solder XBee module onto it, it is difficult to take off XBee module. Preferable, get yourself a female header where you can still insert and take off the Xbee module if you want to change it.
Return to PCB Design
