Unable to get Dot Matrix Clock working properly
Please feedback the issue encountered while using Cytron official website (http://www.cytron.com.my), Cytron Technical Forum and Cytron Tutorial site (http://tutorial.cytron.com.my) here. We greatly appreciate any comments and suggestions too.
Postby zhixiong86 » Fri May 01, 2020 7:39 am
This is my first time getting a Arduino kit to star exploring it, however i'm having some issues.
I'm following https://tutorial.cytron.io/2019/10/23/d ... ing-esp32/ , it seems all pin are proper and setup are correct.
The dot matrix display seems to be not in the right order, what could be wrong? Please refer to pic. Thanks!
zhixiong86
Re: Unable to get Dot Matrix Clock working properly
Postby Idris » Tue May 05, 2020 10:10 am
Hi zhixiong86,
Try to edit the code. Uncomment line 34 and comment line 35. In other words, try to #define HARDWARE_TYPE MD_MAX72XX::FC16_HW and program again. Please let me know the result. Thanks.
Postby zhixiong86 » Sun May 10, 2020 6:17 pm
Thanks, it working now!
Now I only manage to get it running after I upload the code from the Arduino IDE, how to make it work without reuploading?
zhixiong86
Postby rodyeo » Sun Apr 11, 2021 12:30 am
zhixiong86 WROTE:Thanks, it working now!
Maybe can check my postings... https://m.facebook.com/story.php?story_ ... =554017662
You do not need to "Check/Compile" and "Upload" the code again... you only do it once and unplug the USB cable from the PC and plug it back to regular DC 5V adaptor and it will run but it self from the ESP32 programmed chip... I hope that tips helps....
*** Wait! the FTDI driver is not recognized by Windows Device Manager... FT231X USB UART driver is not installed yet! https://ftdichip.com/drivers/vcp-drivers/ [Select Windows Drivers!]
What to do if a non listed device in the Board Manager Library... add aditional board manager url link at ... Click 'File - Preferences', click the link below, copy the 'Stable release link' and paste it in 'Additional Boards Manager URLs'
 https://github.com/espressif/arduino-esp32/blob/master/docs/arduino-ide/boards_manager.md
Then click 'Tools - Board - Board Manager...' Wait for a while for 'Downloading platform index'. Scroll down, install "esp32".
*** Important: Please download and use custom NTPClient v.3.1.0 Library Manager created by Idris @ Cytron.io only, else you will get error... "No Clock Time display on the Dot Matrix Display". https://github.com/taranais/NTPClient/a ... master.zip
Rodney @ http://rodyeo.dyndns.org
NTPClient v.3.10 Library Manager created by Idris @ Cytron.io
ESP32 Dev Module Board Manager selected
Include Library Add ZIP Library
Manage Library
rodyeo
Postby jcheong » Thu Mar 31, 2022 3:03 pm
I've changed the code to use the standard NTP library.
However, I have not incorporated a "sleep" timer when querying the NTP server, hence I have redirected the queries to an internal NTP server on my home network so as not to overload the public NTP servers.
Let me know if anyone is interested but I would ask that you be responsible and not overload the public NTP servers.
jcheong
