Arduino and LoRa RN2903
Postby junewai1993 » Tue Nov 28, 2017 3:23 pm
Currently, i bought a LoRa Shield from Cytron, and I wonder is it any library and example for Arduino.
If no, how to get it started, any good tutorial to get start
junewai1993
Re: Arduino and LoRa RN2903
Postby bengchet » Tue Nov 28, 2017 6:02 pm
If you have another LoRa shield, you can consider do point to point communication. LoRa shield can be LoRa RN2903 or Cytron LoRa RFM shield.
If you wish to play with LoRaWAN, you will need a LoRa gateway within your area.
If you have 1 and only 1 LoRa shield, basically you cannot start anything yet.
Postby junewai1993 » Wed Nov 29, 2017 7:27 am
Hi, thanks for the reply
The problem we want to highlight is we couldn't get any tutorial or example code/library from cytron LoRa RN2903 official website.
Regarding to the reply, is it means that the tutorial & libraries/example code used for the cytron LoRa RFM shield is also applicable to LoRa RN2903??
Thank you
junewai1993
Postby bengchet » Wed Nov 29, 2017 10:35 am
1. For LoRaWAN, you can use suggested library here
2. For point to point communication, you can refer to this thread
Tutorial & libraries/example code used for the cytron LoRa RFM shield is not applicable to Cytron LoRa Shield with RN2903.
