Cytron WiFi Shield
Re: Cytron WiFi Shield
Postby Idris » Fri Apr 19, 2019 12:36 pm
Hi Asyraaf,
This is the latest AT firmware provided by Espressif. You can try it.
https://www.espressif.com/en/support/download/at
Postby Ashraaf » Fri Apr 19, 2019 4:06 pm
Idris WROTE:Hi Asyraaf,
Thanks. Btw how to select which file in the downloaded in the program since the filename is different? So far I only know the firmware can be upgraded using this software only for this shield.
Update: Never mind, I just found out that it is not firmware for ESP-WROOM-02. Just found out the real one.
Ashraaf
Postby ZaM » Fri Apr 19, 2019 4:25 pm
Hi, try used this https://drive.google.com/file/d/1pWaJH4PwwywfEO_A1Q4hSrmOifPx15MX/view?usp=sharing, firmware is version V1.6, already test it.
Result on 19 April, 4pm: https://docs.google.com/spreadsheets/d/ ... =824039466
ZaM
Postby Ashraaf » Fri Apr 19, 2019 4:53 pm
ZaM WROTE:Hi, try used this https://drive.google.com/file/d/1pWaJH4PwwywfEO_A1Q4hSrmOifPx15MX/view?usp=sharing, firmware is version V1.6, already test it.
Thanks. I just tried it. It works.
Ashraaf
Postby ZaM » Wed Apr 24, 2019 11:23 am
afiqahshaharin WROTE:How to code cytron wifi shield with ultrasonic sensor to thingspeak? And how to flash the wifi shield? :cry:
Sorry, your can refer to user manual to flash that wifi shield.
ZaM
