Cytron WiFi Shield
Hello may i ask, based on the wifi demo sketch below is it possible to send data to a different ip adress or cloud and which command is responsible for that ?
- CODE: SELECT_ALL_CODE
#include <CytronWiFiShield.h>
#include <CytronWiFiClient.h>
#include <CytronWiFiServer.h>
#include <SoftwareSerial.h>
const char *ssid = "...";
const char *pass = "...";
IPAddress ip(192, 168, 1 ,242);
ESP8266Server server(80);
"Content-Type: text/html\r\n"
"Connection: close\r\n\r\n"
"<!DOCTYPE HTML>\r\n"
"<html>\r\n";
void setup() {
while (!Serial) {
if(!wifi.begin(2, 3))
while(1);
// Uncomment these 2 lines if you are using static IP Address
// Serial.println(F("Setup wifi config"));
// wifi.config(ip);
while(1);
wifi.updateStatus();
clientTest();
espblink(100);
server.begin();
void loop() {
serverTest();
void espblink(int time)
for(int i = 0;i<12;i++)
delay(time);
void serverTest()
if(client.available()>0)
Serial.println(req);
return;
Serial.print(F("Request: "));
client.flush();
if(req.equals("/"))
client.print(htmlHeader);
htmlBody += ipStr;
client.print(htmlBody);
String htmlBody="";
for (int a = 0; a < 6; a++)
htmlBody += "A";
htmlBody += String(a);
htmlBody += ": ";
htmlBody += "<br>\r\n";
else if(req.equals("/gpio2"))
htmlBody += "</html>\r\n";
else if(req.equals("/info"))
client.print(toSend);
client.print("</html>\r\n");
else
client.stop();
void clientTest()
ESP8266Client client;
client.stop();
return;
"Host: http://www.adafruit.com\r\n"
"Connection: close\r\n\r\n";
client.stop();
return;;
int i=5000;
delay(1);
if(i==1) {
Serial.println(F("Timeout"));
return;
while (client.available()>0)
//Serial.print(c);
Serial.write(client.read());
client.stop();
