Cytron WiFi Shield (WiFi Demo)
Posted: Wed Aug 29, 2018 11:11 am
Hello, i want to ask regarding the Cytron wifi shield wifi demo sketch, i manage to tweak the coding to display my own data to the local ip address, and when i add an lcd display to the skecth it failed to upload the data to the ip address but it does display on the lcd. May i ask why and how to resolve this ?
this is my sketch btw, i already comment out the lcd display command
#include <CytronWiFiShield.h>
#include <CytronWiFiClient.h>
#include <CytronWiFiServer.h>
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int LED = 10;
//int LED2 = 13;
int sensor = 8;
int sensorCounter = 0; // counter for the number of button presses
int sensorState = 0; // current state of the sensor
int lastSensorState = 0;
const char *ssid = "ferntea2500@unifi";
const char *pass = "tiramisu2016";
IPAddress ip(192, 168, 1 ,242);
ESP8266Server server(80);
"Content-Type: text/html\r\n"
"Connection: close\r\n\r\n"
"<!DOCTYPE HTML>\r\n"
"<html>\r\n";
void setup() {
pinMode(LED,OUTPUT);
//pinMode(LED2,OUTPUT);
pinMode(sensor,INPUT_PULLUP);
while (!Serial) {
if(!wifi.begin(2, 3))
while(1);
// Uncomment these 2 lines if you are using static IP Address
// Serial.println(F("Setup wifi config"));
// wifi.config(ip);
while(1);
wifi.updateStatus();
clientTest();
espblink(100);
server.begin();
// lcd.begin(16, 2);
// Print a message to the LCD.
// lcd.print("Chocolate Count!");
void loop() {
sensorState = digitalRead(sensor);
if(sensorState != lastSensorState){
if(sensorState == LOW){
sensorCounter++;
Serial.println("Chocolate: ");
Serial.println(sensorCounter);
// lcd.setCursor(0, 1);
// lcd.print(sensorCounter);
digitalWrite(LED,HIGH);
delay(50);
digitalWrite(LED,LOW);
lastSensorState = sensorState;
serverTest();
void espblink(int time)
for(int i = 0;i<12;i++)
delay(time);
void serverTest()
if(client.available()>0)
Serial.println(req);
return;
Serial.print(F("Request: "));
client.flush();
if(req.equals("/"))
client.print(htmlHeader);
String htmlBody = "Chocolate Value : ";
float cvalue = sensorCounter;
// htmlBody += ipStr;
// htmlBody += "</html>\r\n\r\n";
client.print(htmlBody);
client.print(cvalue);
String htmlBody="";
for (int a = 0; a < 6; a++)
htmlBody += "A";
htmlBody += String(a);
htmlBody += ": ";
htmlBody += "<br>\r\n";
else if(req.equals("/gpio2"))
htmlBody += "</html>\r\n";
else if(req.equals("/info"))
client.print(toSend);
client.print("</html>\r\n");
else
client.stop();
void clientTest()
ESP8266Client client;
client.stop();
return;
"Host: http://www.adafruit.com\r\n"
"Connection: close\r\n\r\n";
client.stop();
return;;
int i=5000;
delay(1);
if(i==1) {
Serial.println(F("Timeout"));
return;
while (client.available()>0)
//Serial.print(c);
Serial.write(client.read());
client.stop();
int LED = 10;
//int LED2 = 13;
int sensor = 8;
"<html>\r\n";
void setup() {
while (!Serial) {
while(1);
// wifi.config(ip);
while(1);
clientTest();
espblink(100);
server.begin();
void loop() {
sensorCounter++;
delay(50);
serverTest();
delay(time);
void serverTest()
return;
client.flush();
if(req.equals("/"))
String htmlBody="";
htmlBody += "A";
htmlBody += ": ";
else
client.stop();
void clientTest()
client.stop();
return;
client.stop();
return;;
int i=5000;
delay(1);
if(i==1) {
return;
//Serial.print(c);
client.stop();
