cytron wifi shield+ arduino mega can't communicate with blyn
Postby raff_696969 » Sun Mar 24, 2019 12:17 pm
i have a problem where when i stack the cytron wifi shield and perform AT test its work accordingly. But when i tried to use it to connect to blynk app it fail. Btw i'm using arduino mega.
raff_696969
Re: cytron wifi shield+ arduino mega can't communicate with
Postby ober » Tue Mar 26, 2019 6:59 am
Which sample code you are using and mind share the detailed setup? The question is too general for us to help.
Postby ZaM » Sun Apr 21, 2019 4:14 pm
Hi, do your problem already solved? If using Arduino mega, set TX and RX to pin D10 and D11.
ZaM
