Cytron Wifi Shield with Mega 2560 using hardware serial
Postby wayves » Fri Dec 18, 2020 12:19 am
Hi, is it possible to use hardware serial instead of software serial for an Arduino Mega 2560 stacked to a Cytron Wifi Shield 2.0? If its possible, can you share the code?
wayves
Re: Cytron Wifi Shield with Mega 2560 using hardware serial
Postby ZaM » Tue Dec 22, 2020 12:31 pm
Yes, it is possible, you can use pin D1 and D0. For the code is still the same, just change the software serial pin to the hardware pin, and remove your Serial Monitor output.
ZaM
Postby sahiikart123 » Mon Jan 25, 2021 3:05 pm
If you have a business and you want to grow your business online in Delhi, here is how you can hire a good Marketing Agency for SEO Service Provider in Delhi. Search Engine Optimization is almost the backbone of every small business. If you want to grow your organic traffic and organic sales online, you need to optimize your website for well ranking in Google and other search engines as well.
https://digitalakki.com/blog/seo-service-provider-in-delhi/
sahiikart123
Users browsing this forum: No registered users and 33 guests
