Raspberry Pi 3 with Arduino UNO
Tue Mar 06, 2018 10:59 am
by tiqaae
Hi. Has anyone tried to do an IoT project using Raspberry Pi 3 and Arduino Uno?
If anyone could share the software and hardware use?
Re: Raspberry Pi 3 with Arduino UNO
Tue Mar 06, 2018 11:06 am
by Idris
Hi tiqaee,
Any reason why to combine Raspberry Pi 3 and Arduino Uno? I think you can develop IoT project based on one of this.
Thu Mar 29, 2018 4:54 am
by derrick
Google around. You can find some examples on it. I've tried IoT based home automation using raspberry pi 3 before. Can try the link
https://circuitdigest.com/microcontroller-projects/iot-raspberry-pi-home-automation.
But if what you mean is IoT based project using both Arduino UNO and raspberry pi together, I didn't get to try it out. Like Idris asked, is there a reason to do so? One of the two boards should be sufficient for simple project
Fri Apr 05, 2019 11:52 am
by saran
Actually im having same doubt as you posted earlier, guess it could probably due certain aspect like
- range of sensors available
- interaction between sensors and main board
- Price and Support
seriously, I found raspberry pi has more feature in term controlling all the aspect(main board) and database support while Arduino more toward end part where its connection to sensor and send signal to pi...
My latest project on smart aquarium on which i wish to combine both this board for best solution. Will update my project once completed.Tx
