sensor 5 dof imu
sensor 5 dof imu
Postby hendrifauzam » Sun Mar 13, 2016 12:01 pm
can anyone help me how to connect this sensor to arduino UNO and motor driver ?
hendrifauzam
Re: sensor 5 dof imu
Postby ZaM » Mon Mar 14, 2016 4:08 pm
Connection would not be difficult, but using it will take some understanding and work. As the output of this sensor is analog, you can simply connect to Arduino UNO's analog input pins, which is A0 to A5, any pin would do the works. As for motor driver, you can use 2A motor shield which does not need manual interface, just stack it on to Arduino UNO. The part where you need to study and try is software, which combine the input signal of IMU and control the driver :)
ZaM
sensor 5 dof imu Humidity requirements
Postby kennylim » Fri Nov 24, 2017 10:47 am
I'm designing something to include this IMU for long term use
I searched the datasheets and did not find RH humidity requirements.
The closest i got was the following for Gyro sensors
"Also avoid exposure to moisture. Store the products
where the temperature and relative humidity do not
exceed 5 to 40°C and 20 to 75%R.H. Srore the
products in a sealed bag and use with in 6 months."
Need help to find out the RH operating and storage conditions
Kenny
kennylim
Postby ober » Sun Nov 26, 2017 6:41 am
Well, if the datasheet does not state it, we do not know too.
Users browsing this forum: No registered users and 31 guests
