control robot using other program
Re: control robot using other program
Postby zamlak » Fri Mar 05, 2010 11:01 am
The new code
void wireless_xbee (void)
{   lcd_clr();                                                // clear the lcd
   while(1)                                                // looping forever
      lcd_goto (0);
      if (data[0] == 100)                                       // check if UART start byte is met
         send_string("  XBEE CONTROL  ");                        // display string
         SPEEDL = 200;                                       // set the motor speed
         SPEEDR = 200;
            lcd_goto(20);
            if (RCREG == '8')                                    // if character '8' is detected, the robot move forward
               forward();
               send_string("FORWARD        ");
               while(TXIF==0);   //only send the new data after the previous data finish sent
               TXREG='F';
               while(TXIF==0);
               TXREG='O';
               while(TXIF==0);
               TXREG='R';
               while(TXIF==0);
               TXREG='W';
               while(TXIF==0);
               TXREG='A';
               while(TXIF==0);
               TXREG='R';
               while(TXIF==0);
               TXREG='D';
            else if (RCREG == '2')                                 // if character '2' is detected, the robot move backward
               backward();
               send_string("BACKWARD        ");
               TXREG='B';
               while(TXIF==0);
               TXREG='A';
               while(TXIF==0);
               TXREG='C';
               while(TXIF==0);
               TXREG='K';
               while(TXIF==0);
               TXREG='W';
               while(TXIF==0);
               TXREG='A';
               while(TXIF==0);
               TXREG='R';
               while(TXIF==0);
               TXREG='D';
            else if (RCREG == '6')                                 // if character '6' is detected, the robot turn right
               right();
               send_string("TURN RIGHT      ");
               TXREG='R';
               while(TXIF==0);
               TXREG='I';
               while(TXIF==0);
               TXREG='G';
               while(TXIF==0);
               TXREG='H';
               while(TXIF==0);
               TXREG='T';
            else if (RCREG == '4')                                 // if character '4' is detected, the robot turn left
               left();
               send_string("TURN LEFT       ");
               TXREG='L';
               while(TXIF==0);
               TXREG='E';
               while(TXIF==0);
               TXREG='F';
               while(TXIF==0);
               TXREG='T';
            else if (RCREG == '5')                                  // if character '5' is detected, then stop the robot
               stop();
               send_string("INVALID COMMAND  ");
               TXREG='S';
               while(TXIF==0);
               TXREG='T';
               while(TXIF==0);
               TXREG='O';
               while(TXIF==0);
               TXREG='P';
            else                                              // else then stop the robot
               stop();
               TXREG='I';
               while(TXIF==0);
               TXREG='N';
               while(TXIF==0);
               TXREG='V';
               while(TXIF==0);
               TXREG='A';
               while(TXIF==0);
               TXREG='L';
               while(TXIF==0);
               TXREG='I';
               while(TXIF==0);
               TXREG='D';
      else    send_string("COMMAND");
The previous code for textReceived==RCREG does not gives any effect.May i know how to view (coding in pic) what the character that have been send to the robot.For example when we enter '8' at vb what form that the data been sent.data[0]=100 is detecting 'd' from vb to start controlling the robot using keyboard.Please help me.Thank you.
zamlak
Postby tkleong1437 » Thu Jun 17, 2010 1:33 am
Try check does ur robot section receive extra character such as vbCr or vbCRLF from PC.
tkleong1437
