Full Command of SC16A and Samples
Postby lkp857 » Tue Sep 21, 2010 5:02 pm
Guys, can anyone of you provide me the full list of command?
In the provided sample and guides, only two things we can do:
1) Rotote the Servo
2) Get the position of Servo
Can we send a command to turn on / off the servo? or some other thing that it can do?
lkp857
Re: Full Command of SC16A and Samples
Postby redips_id » Tue Sep 21, 2010 7:19 pm
Hi lkp857, this is my opinion..
lkp857 WROTE:Can we send a command to turn on/off the servo? or some other thing that it can do?
To turn ON/OFF servo you need to connect/disconnect the servo supply. You can add mosfet/relay or any switching component at the servo supply and it should be able to handle in high current (because servo operate in high current). For 'some other thing that it can do' maybe you can refer to Cytron IFC Servo Card functions.
redips_id
Postby hyng » Wed Sep 22, 2010 9:13 am
This servo controller only has these two functions. You can manipulate these functions to achieve your project.
