dual brush card
dual brush card
Postby bear » Wed Oct 06, 2010 1:26 am
why the led of cw or ccw blinking, thus the output motor rotate very slowly synchronise with led blinking... :?
bear
Re: dual brush card
Postby A380 » Wed Oct 06, 2010 11:25 am
Did you call any function to run it from IFC-MB00?
A380
Re: dual brush card
Postby bear » Wed Oct 06, 2010 5:49 pm
something like that.. i call function to run it from ifc cp04..
bear
Re: dual brush card
Postby robosang » Wed Oct 06, 2010 6:12 pm
bear WROTE:something like that.. i call function to run it from ifc cp04..
Good answer :shock:
Re: dual brush card
Postby bear » Wed Oct 06, 2010 6:30 pm
asal semak.. sukati aq nk ja wab ape.. anyway, call function using cp04 switch is same as calling function using mb00 switch..
bear
Re: dual brush card
Postby A380 » Wed Oct 06, 2010 7:44 pm
Have you try the IFC-BH02 sample source code? You can download it form here --> http://www.cytron.com.my/viewProduct.ph ... yRktmdzN4=
Try it and check whether that card can run as normal or not..
A380
