ifc power supply
ifc power supply
Postby bear » Wed Oct 06, 2010 6:01 pm
how to make external power supply for card such as bl02, bh02 so it will has own power supply.. dont want to use power supply from power card..
bear
Re: ifc power supply
Postby yonghui » Fri Nov 05, 2010 9:39 pm
the boards supply is always shared together from the power card, the communications need common ground. but for the motors u can use separate supply, not necessary the supply from power card. just connect the cable of the motor supply to ur own supply. check for the schematic of th board. using the power card actually provides some advantages in term of the overload, and reverse polarity protection.
