which driver motor is better?? md30b? md10b?
Postby d-nano » Thu Mar 03, 2011 2:29 am
im using i/o terminal block from humusoft (tb620)
and i want to connect it with driver motor md30b.
but when i connect the CW port of md30b with i/o card,
the motor will run CCW. I got confused. same goes when i try CCW port, the motor will run CW.
is it md30b broken? but when i test the md30b itself seem to be nothing wrong.
must i use other motor driver such as md10b to get better result? :roll:
d-nano
Re: which driver motor is better?? md30b? md10b?
Postby robosang » Thu Mar 03, 2011 9:50 am
d-nano WROTE:im using i/o terminal block from humusoft (tb620)
I think you can simply change the terminal of motor connected to MD30B to change the direction.
and the terminal block is just an extension, you should have given the DAQ card connected to it.
