Can i just control the servo using PIC16F877A instead of using servo controller such as SC16A?
What are the difference? I really appreciated if some of u guys can elaborate more.
Thanks in advance.
unnamedkalkulus WROTE:Hi guys, i'm new in this field and i would like to ask some question.
Thanks in advance.
Thanks in advance.
unnamedkalkulus WROTE:On the other part, what are the most suitable motor to trigger a paintball marker?
I have DC motor in my mind and perhaps basic DC motor is sufficient to trigger the paintball marker.
hyng WROTE:Not sure about the paintball marker. But if you use DC motor, make sure there is a mechanism/circuit so that your dc motor will not continue pull the trigger.
shahrul WROTE:Paintball marker have 2 type. Mechanical marker or electronic marker.
For mechanical marker, use servo to trigger. Servo is enough torque to trigger it.
For electronic marker, you can modified inside it's and put relay or optoisolator to trigger.
