HOW TO CONTROL SC08A
Postby inspirationalefeks » Mon Apr 04, 2011 4:15 pm
hi, i don't have any idea how to control Servo Control SC08A, i want to connect SC08A with my laptop. Does i need any software to install ?
inspirationalefeks
Re: HOW TO CONTROL SC08A
Postby sich » Mon Apr 04, 2011 8:31 pm
You can use UC00A USB to UART converter to connect to the port dedicated for it on SC08A.
Postby inspirationalefeks » Mon Apr 04, 2011 9:06 pm
sich WROTE:You can use UC00A USB to UART converter to connect to the port dedicated for it on SC08A.
thanks, i already bought UCOOA but i have a bit problem, i mean, i read SC08A manual for detail thing i have to do later on, do i need some GUI or program for my SC08A? sorry ..
inspirationalefeks
Postby inspirationalefeks » Tue Apr 05, 2011 6:21 am
sorry, i'm new on electronic because i'm mechanical student.
i'm doing my project which is simple robotic arm, i have to control 5 servo using SC08A connected to laptop using USB to UART converter ... what program i should use to send command to SC08A to move my servo .. actually, i don't have any idea how it work... please give me some instruction or information regarding this problem.
*i really need some help. :?:
inspirationalefeks
Postby shahrul » Tue Apr 05, 2011 6:45 pm
See the datasheet, the keyword is UART. Learn how to use UART.
Postby inspirationalefeks » Tue Apr 05, 2011 8:01 pm
Thanks.. but i don't have any knowledge about sending command to my SC08A to move my servos.. i just want to control my servo using computer, is there any software compatible with SC08A ? i don't know how to write a code ... can someone give me some idea to write program ? any software related ...
P.S i really need help here :(
inspirationalefeks
Postby shahrul » Tue Apr 05, 2011 9:45 pm
inspirationalefeks WROTE:Thanks.. but i don't have any knowledge about sending command to my SC08A to move my servos.. i just want to control my servo using computer, is there any software compatible with SC08A ? i don't know how to write a code ... can someone give me some idea to write program ? any software related ...
That the keyword 'UART'. No answer software that compatible with SC08A, but the software compatible to interface with 'UART'.
You can use Visual Basic to program and use USB-to-UART converter as interface USB to the SC08A.
Postby hyng » Wed Apr 06, 2011 3:39 pm
At the moment Cytron has not come out with sample GUI for SC08A. If you really need a related software (GUI), you can refer to SC16A's GUI. However, the command that sending to the servo controller is different. You need to modify on the GUI code. The whole GUI project code is free to download.
Postby yonghui » Wed Apr 06, 2011 4:14 pm
hi ,
if u do not need gui, and just need simple command send then i think u can use Hyperterminal of ur windows to send it.
