SOURCE CODE FOR SC08A
Postby megat » Fri Nov 25, 2011 12:47 am
is anyone have the source code for the SC08A? because i want to study the coding.
can i use skkca bluetooth to replace the UC00A?
thank u.
megat
Re: SOURCE CODE FOR SC08A
Postby kl84 » Mon Nov 28, 2011 9:07 pm
I don't think SC08A is an open source product. It's not mentioned in Cytron's page.
Technically you can use SKKCA to replace UC00A, since both boards uses the same USB-to-UART chip. But that requires some modification to the circuit, which might have possibility to spoil your board.
kl84
Postby robosang » Fri Dec 02, 2011 6:14 pm
Yes, agreed with kl84. I don think Cytron open the code for the SC08A, I think is servo controller, right?
Furthermore, you don need to study the code in that controller in order to make it wireless, you should try to replace the wired link, I am sure it can be done. :lol:
