HOW TO CONTROL SC08A WITH MC40SE
did anybody know how to run sc08a with mc40se. the sample source code are for sk40c board. please help..
dadieaxmal WROTE:i want to ask, can servo work if power supply 5 volt is given from target board mc40se...
im afraid that the amp is not enough for servo to operate..
sich WROTE:Please explain your problem clearly. I'm confused which of your board fail to control the servo, and please let us know what do you mean by "did not work". What make it fail? Fail to compile the code? Programming fail? Hex file loaded but it doesn't work the way you want?...
Clean: Deleted file "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\SK40C_16F877A_SC08A.p1".
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\gripper1.cof" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\gripper1.hex" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\gripper1.sym" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\gripper1.map" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\gripper1.hxl" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\startup.lst" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\startup.rlf" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\doprnt.p1" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\doprnt.pre" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\gripper1.obj" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\gripper1.lst" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\gripper1.rlf" doesn't exist.
Clean Warning: File "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\gripper1.sdb" doesn't exist.
Clean: Done.
Build C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\gripper1 for device 16F877A
Using driver C:\Program Files\HI-TECH Software\PICC\9.70\bin\picc.exe
Executing: "C:\Program Files\HI-TECH Software\PICC\9.70\bin\picc.exe" --pass1 "C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\SC08A_Sample Code\SK40C_16F877A_SC08A.c" -q --chip=16F877A -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Executing: "C:\Program Files\HI-TECH Software\PICC\9.70\bin\picc.exe" -ogripper1.cof -mgripper1.map --summary=default --output=default SK40C_16F877A_SC08A.p1 --chip=16F877A -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
(1273) Omniscient Code Generation not available in Lite mode (warning)
HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode) V9.70
Copyright (C) 2009 Microchip Technology Inc.
Memory Summary:
Program space used 14Ah ( 330) of 2000h words ( 4.0%)
Data space used 17h ( 23) of 170h bytes ( 6.3%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
Configuration bits used 1h ( 1) of 1h word (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
Running this compiler in PRO mode, with Omniscient Code Generation enabled,
produces code which is typically 40% smaller than in Lite mode.
The HI-TECH C PRO compiler output for this code could be 132 words smaller.
See http://microchip.htsoft.com/portal/pic_pro for more information.
Loaded C:\Users\Pavilion a6045d\Desktop\Kerja Dadie\robot\gripper\gripper1.cof.
********** Build successful! **********
// Author : CYTRON
// Project : SK40C UART - SC08A
// Project description : Sample code for controlling SC08A
// This sample source code is valid for
// 20MHz crystal.
// Getting started with this sample code
// After connect SK40C with SC08A and Servo Motor using UART, supply the power to both SK40C and SC08A.
// Please bear in mind that, Servo Power for RC servo motor is normally 5-6V depending on the RC Servo Manufacturer
// Switch ON the power supplies, it is normal that the servo motor will vibrate for few second upon power up
// Green and Orange LEDS will be light ON
// Press SW1 on SK40C to activate all 8 channel, servo motor will move to middle position 1.5ms pulses and stay at that position .
// You must press the SW1 first to activate the servo channel.
// After that, press SW2 on SK40C. All the servo channel will move back and forth to each end of position infinity.
// include
#include <pic.h>
// configuration
__CONFIG ( 0x3F32 ); //configuration for the microcontroller
// define
#define SW1 RB0
#define SW2 RB1
#define LED1 RB6
#define LED2 RB7
// function prototype (every function must have a function prototype)
void delay(unsigned long position);
unsigned char uart_rec(void); //receive uart value
void uart_send(unsigned char position);
void uart_str(const char *s);
void position_speed_cmd(unsigned char channel, unsigned int position, unsigned char speed);
void on_off_cmd(unsigned char channel, unsigned char on_off);
unsigned int request_position_cmd(unsigned char channel);
unsigned char compare_position(unsigned char channel, unsigned int position);
void init_servo_cmd(unsigned char channel, unsigned int position);
void store_eeprom(unsigned char position,unsigned char location);
unsigned char get_eeprom(unsigned char location);
//unsigned int read_position(unsigned char channel, unsigned int position);
// global variable
unsigned int position;
// main function (main fucntion of the program)
void main()
unsigned int i,j,k,a=0, temp=0;
unsigned char sp=0;
//set I/O input output
TRISB = 0b00000011; //configure PORTB I/O direction
//Configure UART
SPBRG=129; //set baud rate as 9600 baud for 20Mhz
BRGH=1; //baud rate high speed option
TXEN=1; //enable transmission
TX9 =0; //8-bit transmission
RX9 =0; //8-bit reception
CREN=1; //enable reception
SPEN=1; //enable serial port
SYNC=0; //Asynchronous mode
LED1=0; // OFF LED1
LED2=1; // OFF LED2
sp=50; //speed value for the servo
while(1)
if(SW1==0)
while(SW1==0); //SW1 press and waiting for release
on_off_cmd(0,1); //ON all the channel
LED2^=1;
else if(SW2==0) //if sw is pressed
while(SW2==0); //SW2 press and waiting for release
while(1) //infinity loop
for(k=1; k<9; k++) //servo channel 1-8 loop
position_speed_cmd(k,7000,sp); //send command Servo posisitoning with speed
while(request_position_cmd(1)<6900) //read the position from channel 1 after sending request position command
{ //if the position is smaller than 6900, loop here untill the position is bigger then 6900
for(k=1; k<9; k++) //after position bigger than 6900
{ //servo channel 1-8 loop
position_speed_cmd(k,1000,sp); //send command Servo posisitoning with speed
while(request_position_cmd(1)>1100) //read the position from channel 1 after sending request position command
{ //if the position is bigger than 1100, loop here untill the position is smaller then 1100
//subroutine for SC08A command
//command Servo positioning with speed
void position_speed_cmd(unsigned char channel, unsigned int position, unsigned char speed) //send 4 bytes of command to control servo's position and speed
unsigned char first_byte=0, higher_byte=0, lower_byte=0;
// First byte combined the mode and servo channel
// ob xxx xxxxx (in binary)
// mode channel
// for servo positioning with speed command, the mode value is 0b111xxxxx
first_byte=0b11100000|channel;
higher_byte=(position>>6)&0b01111111; //position value from 0-8000 are greater than a byte
lower_byte=position&0b00111111; //so need two bytes to send
//send command to SC08A in 4 byte - Mode with channel, higher byte of position, lower byte of position, and speed
uart_send(first_byte);
uart_send(higher_byte); //second byte is the higher byte of position 0b0xxxxxxx
uart_send(lower_byte); //third byte is the lower byte of position 0b00xxxxxx
uart_send(speed); //fourth byte is the speed value from 0-100
//command Enable/disable the servo channel
unsigned char first_byte=0;
// mode channel
// for servo positioning with speed command, the mode value is 0b110xxxxx
// channel = 0 meaning all channel
first_byte=0b11000000|channel;
//send command to SC08A in 2 byte - Mode with channel and ON/Off channel
uart_send(on_off); // 2nd byte: 1 = enable/activate; 0= disable/deactivate
//command requesting position of servo channel
unsigned char first_byte=0, check_id, higher_position, low_position;
// mode channel
// for servo positioning with speed command, the mode value is 0b101xxxxx
// the channel value cannot be 0 in this command
first_byte=0b10100000|channel;
//send command to SC08A in 1 byte - Mode with channel; after that SC08A will send back the position value
//Received position from SC08A in 2 byte
higher_position=uart_rec(); //first byte is the higher byte of position 0b0xxxxxxx
low_position=uart_rec(); //second byte is the higher byte of position 0b00xxxxxx
//combine the higher byte and lower byte into 16 bits position
position=higher_position<<6;
position=position|(low_position&0x3F);
return position;
//command servo starting position for next reseting of SC08A
//this command is useful when you need the servo motor position to start at different position (not at the middle position which is the default starting position for the servo)
//this subroutine is not use at the sample program
void init_servo(unsigned char channel, unsigned int position)
// mode channel
// for servo positioning with speed command, the mode value is 0b100xxxxx
first_byte=0b10000000|channel;
//initial position for the servo start on next time
//send command to SC08A in 3 byte - Mode with channel, higher byte of position and lower byte of position
//after that, the SC08A will acknowlegde the MCU with a byte, 0x04
while (uart_rec()!=0x04) //wait the 0x04 value from SC08A
//subroutine for UART
unsigned char uart_rec(void) //receive uart value
unsigned char rec_data;
while(RCIF==0); //wait for data
rec_data = RCREG;
return rec_data; //return the data received
void uart_send(unsigned char data)
while(TXIF==0); //only send the new data after
TXREG=data; //the previous data finish sent
while(*s)uart_send(*s++);
hyng WROTE:Helo,You mean even you test SC08A with SK40C also cannot work? Did you test with the sample code?
Are you sure the connection of UART between SK40C and SC08A is correct? Please make sure the RX of SK40C is connected to TX of SC08A and TX of SK40C is connected to RX of SC08A.
