Need Help With Mini Mobile Robot Controller MC40A
Hello Pros
Need Some Help Here and Cytron Technician also is Needed Here
About Mini Mobile Robot Controller (MC40A) what i have seen in MC40A_Schematic i See only have one ADC port.
Its Is possible to used more than 5ADC in this MC40A By Removing Some Component?
By removing Those Component at :-
-ADC PORT - No Change
-Limit1 Port - By Removing R42 and C17
-Limit2 Port - By Removing R43 and C18
-RE0,RE1,RA3,RA5 Maybe No Change by looking at MC40A_Schematic
-RE2 Is Enable to used without remove Anything When not Using LCD Surely I will used LED maybe the LED E port can be change to Extension PORT
when using PIC 18
-SW1 - By Removing C6 and R3 by Using 1 side of JP16
-SW2 - By Removing C9 and R4 by Using 1 side of JP17
It is Possible ADC can be used when Removing Those Component? No Effect? i now some LIMIT1,LIMIT2,SW1 and SW2 can't be used after removing some component.need to know other effect when removing those component.
Need Help Pros, Cytron Technician, or MC40A Circuit Designer Guy <-- This more easy if this guy have here
when using PIC 18
