How to program 5 MD10C with sk40c with pic16f877a?
Postby samcheong90 » Wed Mar 14, 2012 12:00 pm
hi, so how to program 5 MD10c with pic16f877a? in MD10C the logic is when PWM is high then the motor which connected to MD10C will move in either direction depends on the DIR. so can i just send 1 to PWM in pic to move the motor and controlled by skps? PW3 to PW5 is not working when i press the corresponding button. my code is like:
#define M1_DIR      RC3      //MD10C (1) Enable
#define M1_PWM      CCPR1L   //MD10C (1) PWM register
#define M2_DIR      RC0      //MD10C (2) Enable
#define M2_PWM      CCPR2L   //MD1OC (2) PWM register
#define PW3_DIR     RC4
#define PW3_PWM       RA5     //Power Window (3)
#define PW4_DIR     RA0
#define PW4_PWM       RA1     //Power Window (4)
#define PW5_DIR     RA2
#define PW5_PWM       RA3     //Power Window (5)
//left and right max speed
#define left_max_speed   255
#define right_max_speed   255
      //get data from joystick
      joystick_rightup=SKPS(p_joy_ru);               //get joystick_rightup value from p_joy_ru value
          joystick_rightdown=SKPS(p_joy_rd);              //get joystick_rightdown value from p_joy_rd value
          joystick_rightleft=SKPS(p_joy_rl);              //get joystick_rightleft value from p_joy_rl value
        joystick_rightright=SKPS(p_joy_rr);             //get joystick_rightright value from p_joy_rr value
      joystick_leftup=SKPS(p_joy_lu);               //get joystick_leftup value from p_joy_lu value
          joystick_leftdown=SKPS(p_joy_ld);              //get joystick_leftdown value from p_joy_ld value
          joystick_leftleft=SKPS(p_joy_ll);              //get joystick_leftleft value from p_joy_ll value
        joystick_leftright=SKPS(p_joy_lr);             //get joystick_leftright value from p_joy_lr value
      //calculate left_wheel and right_wheel register from all 4 joystick value
      left_wheel=   joystick_leftleft*left_max_speed/100
               -joystick_leftright*left_max_speed/100;
      right_wheel=   joystick_rightleft*right_max_speed/100
                  -joystick_rightright*right_max_speed/100;
      //limit left wheel and right wheel register to the maximum value
      if(left_wheel>left_max_speed)left_wheel=left_max_speed;
      else if(left_wheel<-left_max_speed)left_wheel=-left_max_speed;
      if(right_wheel>right_max_speed)right_wheel=right_max_speed;
      else if(right_wheel<-right_max_speed)right_wheel=-right_max_speed;
      fleft_wheel=   joystick_leftup*left_max_speed/100
               -joystick_leftdown*left_max_speed/100
               -joystick_rightdown*left_max_speed/100
               +joystick_rightup*left_max_speed/100;
      fright_wheel=   joystick_leftup*left_max_speed/100
      if(fleft_wheel>left_max_speed)fleft_wheel=left_max_speed;
      else if(fleft_wheel<-left_max_speed)fleft_wheel=-left_max_speed;
      if(fright_wheel>right_max_speed)fright_wheel=right_max_speed;
      else if(fright_wheel<-right_max_speed)fright_wheel=-right_max_speed;
      //brake both motor if PS2 controller not connected
      if(SKPS(p_con_status)==0)
         left_wheel=0;
         right_wheel=0;
         fleft_wheel=0;
         fright_wheel=0;
      //control motor driver based on left_wheel and right_wheel value
      if(left_wheel>0)      //left forward
         M1_DIR=0;
         M1_PWM=(unsigned char)left_wheel;
      else if(left_wheel<0)   //left reverse
         M1_DIR=1;
         M1_PWM=(unsigned char)(-left_wheel);
      else               //left brake
         M1_PWM=0;
      if(right_wheel>0)      //right forward
         M2_DIR=1;
         M2_PWM=(unsigned char)right_wheel;
      else if(right_wheel<0)   //right forward
         M2_DIR=0;
         M2_PWM=(unsigned char)(-right_wheel);
      else               //right brake
         M2_PWM=0;
      if(fleft_wheel>0)      //left forward
         M1_DIR=0;
         M1_PWM=(unsigned char)fleft_wheel;
      else if(fleft_wheel<0)   //left reverse
         M1_DIR=1;
         M1_PWM=(unsigned char)(-fleft_wheel);
      else               //left brake
         M1_PWM=0;
      if(fright_wheel>0)      //right forward
         M2_DIR=1;
         M2_PWM=(unsigned char)fright_wheel;
      else if(fright_wheel<0)   //right forward
         M2_DIR=0;
         M2_PWM=(unsigned char)(-fright_wheel);
      else               //right brake
         M2_PWM=0;
      //control up,down,in,out,gripper motion
      if(SKPS(p_up)==0)
         PW3_PWM=1;
         PW3_DIR=0;
      else if(SKPS(p_down)==0)
         PW3_PWM=1;
         PW3_DIR=1;
      else
         PW3_PWM=0;
      if(SKPS(p_left)==0)
         PW4_PWM=1;
         PW4_DIR=0;
      else if(SKPS(p_right)==0)
         PW4_PWM=1;
         PW4_DIR=1;
      else
         PW4_PWM=0;
      if(SKPS(p_triangle)==0)
         PW5_PWM=1;
         PW5_DIR=0;
      else if(SKPS(p_cross)==0)
         PW5_PWM=1;
         PW5_DIR=1;
      else
         PW5_PWM=0;
did my code had any problem? or is it i cannot just send the signal 1 to PWM to run the motor?PW3 to PW5 i don't want speed control i just want to control the motor to move when skps's button is push.
samcheong90
