Servo Motor Shaking
PostPosted: Sat Jul 07, 2012 3:45 pm
by domdom
Hi All,
I am using SC16A servo motor controller to drive 12 sets of servo motor (Tower Pro MG995) with Power supply of 5V & current limit 5A.
Sometimes I feel some of the servo motors are shaking whenever I change their rotation. If all the motors are not shaking, the total current consumption would be ~0.08A. When one of the motor is shaking, it might shoot up to ~0.3A.
Below are the specs of the motor:
Specification shown:
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-7.2 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.20sec/60 degrees
Operating Speed (6.0V): 0.19sec/60 degrees
Stall Torque (4.8V): 9kg.cm
Stall Torque (6.0V): 11kg.cm
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Current Drain (4.8V): 8.8mA/idle and 350mA no load operating
Current Drain (6.0V): 9.1mA/idle and 450mA no load operating
Dead Band Width: 4 usec
Motor Type: 3 Pole Ferrite
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearing
Gear Type: All Metal Gears
Connector Wire Length: 11.81" (300mm)
Dimensions: 1.59" x 0.77"x 1.48" (40.6 x 19.8 x 37.8mm)
Weight: 1.94oz. (55.2g)
May I know what is the possible reason causing this? Should it be the motor driving overload? Anyone can support me about this?
Re: Servo Motor Shaking
PostPosted: Mon Jul 09, 2012 4:10 pm
by robosang
Not familiar with that particular servo, and not really use SC16A before.
Well.... it might be programming, it might power 8-) A video showing the result should be helpful.
PostPosted: Fri Jul 13, 2012 9:30 am
by royalstorm7
from my exp, if your motor are connected to the load, it may be overloading...or there are some jamming in the gear system...good luck!
roslan
royalstorm7@yahoo.com
PostPosted: Fri Jul 13, 2012 11:51 am
by royalstorm7
u can try to use dc geared motor as a servo if you deal with a massive torque...
roslan
PostPosted: Sat Jul 14, 2012 10:08 am
by yonghui
some servo has over torque protection where it cut off when over torque, and on back in a short while. so on and off will cause the servo shaking. try to unload the servo see if it still shaking.
PostPosted: Tue Aug 21, 2012 3:43 pm
by funmix
Thanks for all the comments. I will post up video this week for better understanding. And also I will remove all the loads and test it again.
