Page 1 of 2
Need help on SD02B stepper motor driver
Fri Jul 13, 2012 4:15 pm
by tiongpatrick86
I would like to know whether SD02B stepper motor driver can drive 5V stepper motor or not?
However, i found out that in the user manual stated that it is able to drive stepper motor from 3V-40V. I have tried to connect 5V stepper motor with 5V input supply to SD02B at Vmotor pin and GND pin but the motor didn't move when i pressed the "test" switch (for few second). Any suggestion that I can solve this problem
Re: Need help on SD02B stepper motor driver
Fri Jul 13, 2012 10:27 pm
by robosang
Where did you get the 5V from?
Fri Jul 13, 2012 10:58 pm
by tiongpatrick86
I supply 5V from voltage regulator.
Sat Jul 14, 2012 7:48 am
by robosang
Might not be enough current for the stepper, I do not sure, as I don have the stepper driver.
Sat Jul 14, 2012 10:05 am
by yonghui
try to feel the stepper motor shaft. see if it has some little torque when the test button is being pressed?
Sat Jul 14, 2012 5:19 pm
by hyng
Did the LED on SD02B light ON or blinking?
Sun Jul 15, 2012 7:54 pm
by tiongpatrick86
No. the LED doesnt lighting even holding the test switch.
Mon Jul 16, 2012 8:04 am
by tiongpatrick86
One more question, what will happen if the reset button is pressed during operation? Will it damage the driver? what can Ido?
Mon Jul 16, 2012 11:44 am
by hyng
Pressing the reset button will not damage the driver.
Did the power LED light ON? The mini jumper is at Vin or Vmotor? Some photos of the connections may help to verify the problem. BTW, if you only supply 5V to Vmotor, the circuit will not be powered up thus the driver is not working. You need to supply another voltage from 8V-20V to Vin for the circuit power supply. It is mentioned at page 7.
Mon Jul 16, 2012 2:16 pm
by tiongpatrick86
Now i tried to supply with 12V at Vin. The power LED is on. and the mini jumper is connected at Vin. The output LED still are not light on when the test button is pressed.
