MD30B-Enhanced 30 Amp DC Motor Driver
Postby afandi » Fri Nov 09, 2012 12:28 pm
can we connect this motor driver to the electric power supply? if we do not want to use battery...
afandi
Re: MD30B-Enhanced 30 Amp DC Motor Driver
Postby robosang » Fri Nov 09, 2012 3:54 pm
I uses this motor driver before, like the push button and on board speed control.
Anyway I did consult Cytron before on this matter, their advise is about the flyback current if you are using inductive load such as relay or motor. Battery can consume those flyback current and save the motor driver. But if you are driving small current load or non-inductive load, you can ignore it. 8-)
BTW, just to makesure, your power supply mean DC power supply right?
