MD30B-Enhanced 30 Amp DC Motor Driver with Arduino Uno
Postby rebornkel » Fri Mar 01, 2013 11:30 pm
I have some questions. Is MD30B-Enhanced 30 Amp DC Motor Driver compatible with Arduino Uno?
If it is compatible, how do i connect the Arduino Uno to the motor driver to control the speed of the motor using PWM? It is weird that I have to press the CW/CCW button on the motor driver to run the motor with the PWM.
Need help please and thank you in advanced :D
rebornkel
Re: MD30B-Enhanced 30 Amp DC Motor Driver with Arduino Uno
Postby shahrul » Sat Mar 02, 2013 12:38 am
Yes, it's compatible. Anything possible if you can control digital output and PWM. Just connect the required pin from the motor driver to the right function at Arduino. This is example video but use Motor Driver Shield and chipKIT.
