Mini Mobile Robot Controller(MC40A)
Postby hanifnayan » Mon Apr 22, 2013 6:59 pm
if i want to control 4 motor .. can Mini Mobile Robot Controller(MC40A) do it... i notice this microcontroller can support 2 motor.. other 2 motor , i think to build their own driver...
other what is mean by Free IO pins are extended out for further development.... how many input that their have...
thank you..
hanifnayan
Re: Mini Mobile Robot Controller(MC40A)
Postby robosang » Mon Apr 22, 2013 11:50 pm
I have 1 MC40A from last year 1 cent promotion :)
The on board Driver is L293B, you should be able to control up to 1A of current for motor. Extra 2 motor you need to use the free IO. The free IO means the part where you see the header pin at prototyping area, near to LCD.
Postby hanifnayan » Thu Apr 25, 2013 11:05 pm
is that the correct connection of L293B..
PIN OUT OF L293D
board layout of MC4OA
is that true that C is represent the free IO that ur talking about. ..
if true how many port/pin that are available(not used)..
if ur have any picture may its will help me...
thank you su much for helping me...
thank a lot.......
hanifnayan
Postby robosang » Sat Apr 27, 2013 8:53 pm
If you look at the User's Manual clearly, it do state that the pins under the prototyping section are the free IO pins.
Also, check the schematic.
Postby hanifnayan » Mon Apr 29, 2013 3:34 pm
sir .. thank for the feedback...
what i was dont's understand is connection... i mean wiring to the other 2 motor and the input so that i cant control its at the programming....
i ur have any pic pls upload here...
hanifnayan
