Power Supply for SmartDrive40
Hi, i am using 2 units of the smart drive in RC mix mode to control 2 24v dc brush motor.
I tried to supply both smart drive with a shared supply of 24v provided by a liPo battery but encounter Mosfet error (Led blink 6 times)
Does each smart drive require independent supply & cannot share from the same source?
Or i might have done this wrong, so i would like to share i really want to do..perhaps you offer some suggestion.
Actually i use a shared supply because i want to have ONE SWITCH that will turn ON both smart drive at the same time. Therefore, what i did is from the 24v supply, a switch is added before the supply is split to TWO and connected to each smart drive. Please advise on this matter. Thanks in advance.
