Remote Mobile Robot with XBee-WiFi
Postby mohamadhanifnayan » Thu Oct 10, 2013 9:16 pm
im at final stage…
Robot will send some string to the HyperTerminal, then it will move a little left and right to test the motor. Once you get the “Ready!” string… i receive this at hyperterminal......
but when i press w for example nothing happen… i need help here...
the connection between xbee and hyperterminal is ok...
so ... i thing maybe the programming is the problem...
http://tutorial.cytron.com.my/wp-conten ... eRobot.zip
i really need advise here.. hopefully someone will help me...
mohamadhanifnayan
Re: Remote Mobile Robot with XBee-WiFi
Postby Idris » Wed Oct 16, 2013 5:18 pm
Hi mohamadhanifnayan,
After doing the Xbee-WiFi configuration, did you test the both way communication? I mean laptop send data to Xbee-WiFi, Xbee-WiFi send data to laptop.
Postby mohamadhanifnayan » Thu Oct 17, 2013 10:10 pm
is that what u mean
this is my result
after that i cannot press anymore.... sw2 or sw1
i receive xbee wifi S6B.. is should be no problem right !!!!..
mohamadhanifnayan
Postby Idris » Sat Oct 19, 2013 10:54 pm
Hmm, it looks like all the configuration are OK. But I still can't trace the problem.
You are using the same hardware as tutorial?
Postby mohamadhanifnayan » Mon Oct 21, 2013 8:31 pm
yerp... but for motor i use SPG50-20K..
i receive xbee wifi S6B ... your S6... is that ok...
thank..
mohamadhanifnayan
Postby ober » Thu Oct 24, 2013 5:56 pm
Mind sharing the photo of the hardware/wiring of the robot? Do show the connection from microcontroller to the SKXBee with the XBee-WiFi.
Postby mohamadhanifnayan » Mon Oct 28, 2013 11:14 pm
this what i mean...
mohamadhanifnayan
Postby robosang » Mon Oct 28, 2013 11:24 pm
I don follow this thread, but I am interested to see the setting under the SKXBee. Can you share another photo without the SKXbee?
