how to use IFC AI08
how to use IFC AI08
Postby dirayim » Tue Mar 04, 2014 2:14 pm
please help me use this IFC card....IFC AI08....i want to use sensor CX422 to connect to this card...but I don't know how to write the right programming.....
dirayim
Re: how to use IFC AI08
Postby ober » Tue Mar 04, 2014 9:17 pm
IFC-AI08 is analog input card while CX422 is digital output sensor. IFC-AI08 is not designed for digital type of sensor. You should connect CX422 to IFC-DI08 instead.
Postby dirayim » Fri Mar 07, 2014 3:27 pm
sorry...I wrong write the model of the sensor...I want to use sensor infrared sensor..the name of the model is SHARP....can you give an example coding how to use that sensor with IFC AI08....
dirayim
Postby sich » Mon Mar 10, 2014 11:16 am
The sample code is given at the product page.
Postby yonghui » Mon Mar 10, 2014 12:06 pm
to write code , u can refer to IFC-AI08 library reference doc.
there should be function to call to get the value of analog channel that u connect the sensor to.
Postby ober » Tue Mar 11, 2014 8:23 am
Hi, we do not have library for all the analog sensors, there are thousand of analog :)
Even we shrink the sensor to Sharp Infrared distance sensor, there are at least 5 models that I know of, all these sensors have analog output which provide different information at certain voltage. So writing a universal sample code is not possible.
You will need to ready the datasheet of that particular sensor and under the relationship between voltage and distance, further understand the value of ADC function in IFC-AI08, finally, convert the ADC value to distance.
You can try study theexample code of PR23 R2 where we convert the ADC to distance in cm.
Postby dirayim » Fri Mar 14, 2014 12:32 pm
can help me for the program for fire fighting robot...I wan use the sharp infrared sensor to detect the wall....
dirayim
Postby yonghui » Mon Mar 17, 2014 10:26 am
I hope u can please try to write your own code?
