SC08A and command
SC08A and command
Postby sahniana » Thu Jun 12, 2014 5:43 pm
i dont really understand on how to write the sc08a command in mikrobasic language. please guide.
sahniana
Re: SC08A and command
Postby sahniana » Sat Jun 14, 2014 12:41 pm
here's my code:
dim position as integer
dim position1 as integer
dim position2 as string[20]
dim position3 as string[20]
dim thechannel as integer
dim thechannel2 as string[3]
thechannel=0
position=5000
position1=position>>6
inttostr(position,position3)
inttostr(position1,position2)
do
inttostr(thechannel,thechannel2)
uart1_write_text("0b11100000 |")
uart1_write_text(thechannel2)
uart1_write_text(position2)
uart1_write_text("0b01111111")
uart1_write_text(position3)
uart1_write_text("0b00111111")
uart1_write_text("50")
inc(thechannel)
loop until thechannel=7
no response = doesnt work. anyone can exlain why? by the way, i dislayed the position3, position2 and thechannel2 on lcd, and here's what i got:-
position3 = 5000
position2 = 78
thechannel2 = 50
anything wrong with my code?
sahniana
Postby sahniana » Sat Jun 14, 2014 5:51 pm
ive connect to PC using uc00b, testing using sc08a gui. got error, "rc_report.fail1". what does it means?
sahniana
Postby yonghui » Sun Jun 15, 2014 4:30 pm
Have try look at citron tutorial?
http://tutorial.cytron.com.my/2011/08/1 ... project-2/
Sent from my T100TA using Tapatalk
Postby sahniana » Sun Jun 15, 2014 5:23 pm
yonghui WROTE:Have try look at citron tutorial?
yes. still got error. fault board? but i push the test button, the servo run.
sahniana
Postby yonghui » Mon Jun 16, 2014 10:02 am
i think the error u mentioned come from the GUI software. maybe the visual studion version incompatible? mayb u can try to recompile the GUI. or mayb u can send packet through terminal software like XCTU to test?
Postby gadgetng » Mon Jun 16, 2014 4:01 pm
sahniana WROTE:here's my code:
thechannel=0
position=5000
do
inc(thechannel)
position3 = 5000
position2 = 78
thechannel2 = 50
Hi, i never use mikrobasic before therefore i not really understand on your code. Maybe you should put some comment on your code so that ppl can easily understand the coding. Just to remind you that you need to activate the servo channel on SC08A everytime SC08A is power up. I checked on the SC08A's UM, you will need to send two bytes of command to activate the servo channel so that the servo will respond to you at position and speed command.
gadgetng
Postby sahniana » Mon Jun 16, 2014 8:37 pm
thechannel=0
position=5000
do
inc(thechannel)
position3 = 5000
position2 = 78
thechannel2 = 50
i just modified the code from cytron arduino tutorial to mikrobasic language style. n currently, the windows app provided by cytron cant control the board too. is this mean that my sc08a is not functioning well?
sahniana
Postby gadgetng » Tue Jun 17, 2014 8:17 am
Since it is working with the test button, i don't think is the SC08A problem. Maybe you can try to use Arduino to test on it first. :lol:
gadgetng
Postby sahniana » Tue Jun 17, 2014 5:46 pm
gadgetng WROTE:Since it is working with the test button, i don't think is the SC08A problem. Maybe you can try to use Arduino to test on it first. :lol:
u got a point there.i think i will try to communicate with pc first, need to build new application for it..
sahniana
