SmartDrive40 controlled By Arduino Mega
Fri Oct 24, 2014 4:29 pm
by roymeyismail
Why motor cannot rotate counter clockwise even i'm refer tutorial by cytron including the source code given??? Motor only rotate clockwise, for info i'm using ps2 controller to control clockwise and counter clockwise.
Re: SmartDrive40 controlled By Arduino Mega
Fri Oct 24, 2014 5:43 pm
by yonghui
I think u will need to write more to explain.
try to take photo of your project setup.
post your code too.
Mon Nov 03, 2014 4:07 pm
by roymeyismail
- CODE: SELECT_ALL_CODE
#include <PS2X_lib.h> //for v1.6
#include <Servo.h>
PS2X ps2x; // create PS2 Controller Class
//right now, the library does NOT support hot pluggable controllers, meaning
//you must always either restart your Arduino after you conect the controller,
//or call config_gamepad(pins) again after connecting the controller.
int error = 0;
byte type = 0;
byte vibrate = 0;
const int dir_1 = 22;
const int pwm_1 = 2;
const int dir_2 = 23;
const int pwm_2 = 3;
Servo myservo1; // create servo object to control a servo
Servo myservo2; // a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
void setup(){
Serial.begin(57600);
//CHANGES for v1.6 HERE!!! **************PAY ATTENTION*************
error = ps2x.config_gamepad(13,11,10,12, true, true); //setup pins and settings: GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
if(error == 0){
Serial.println("Found Controller, configured successful");
Serial.println("Try out all the buttons, X will vibrate the controller, faster as you press harder;");
Serial.println("holding L1 or R1 will print out the analog stick values.");
Serial.println("Go to www.billporter.info for updates and to report bugs.");
pinMode(pwm_1, OUTPUT);
pinMode(dir_1, OUTPUT);
pinMode(dir_2, OUTPUT);
pinMode(pwm_2, OUTPUT);
myservo1.attach(9); // attaches the servo on pin 9 to the servo object
myservo2.attach(8);
else if(error == 1)
Serial.println("No controller found, check wiring, see readme.txt to enable debug. visit www.billporter.info for troubleshooting tips");
else if(error == 2)
Serial.println("Controller found but not accepting commands. see readme.txt to enable debug. Visit www.billporter.info for troubleshooting tips");
else if(error == 3)
Serial.println("Controller refusing to enter Pressures mode, may not support it. ");
//Serial.print(ps2x.Analog(1), HEX);
type = ps2x.readType();
switch(type) {
case 0:
Serial.println("Unknown Controller type");
break;
case 1:
Serial.println("DualShock Controller Found");
break;
case 2:
Serial.println("GuitarHero Controller Found");
break;
void loop(){
/* You must Read Gamepad to get new values
Read GamePad and set vibration values
ps2x.read_gamepad(small motor on/off, larger motor strenght from 0-255)
if you don't enable the rumble, use ps2x.read_gamepad(); with no values
you should call this at least once a second
if(error == 1) //skip loop if no controller found
return;
if(type == 2){ //Guitar Hero Controller
ps2x.read_gamepad(); //read controller
if(ps2x.ButtonPressed(GREEN_FRET))
Serial.println("Green Fret Pressed");
if(ps2x.ButtonPressed(RED_FRET))
Serial.println("Red Fret Pressed");
if(ps2x.ButtonPressed(YELLOW_FRET))
Serial.println("Yellow Fret Pressed");
if(ps2x.ButtonPressed(BLUE_FRET))
Serial.println("Blue Fret Pressed");
if(ps2x.ButtonPressed(ORANGE_FRET))
Serial.println("Orange Fret Pressed");
if(ps2x.ButtonPressed(STAR_POWER))
Serial.println("Star Power Command");
if(ps2x.Button(UP_STRUM)) //will be TRUE as long as button is pressed
Serial.println("Up Strum");
if(ps2x.Button(DOWN_STRUM))
Serial.println("DOWN Strum");
if(ps2x.Button(PSB_START)) //will be TRUE as long as button is pressed
Serial.println("Start is being held");
if(ps2x.Button(PSB_SELECT))
Serial.println("Select is being held");
if(ps2x.Button(ORANGE_FRET)) // print stick value IF TRUE
Serial.print("Wammy Bar Position:");
Serial.println(ps2x.Analog(WHAMMY_BAR), DEC);
else { //DualShock Controller
ps2x.read_gamepad(false, vibrate); //read controller and set large motor to spin at 'vibrate' speed
if(ps2x.Button(PSB_PAD_UP)) { //will be TRUE as long as button is pressed
Serial.print("Up held this hard: ");
Serial.println(ps2x.Analog(PSAB_PAD_UP), DEC);
digitalWrite(dir_1,HIGH);
analogWrite(pwm_1,100);
digitalWrite(dir_2,HIGH);
analogWrite(pwm_2,100);
delay(200);
if(ps2x.Button(PSB_PAD_RIGHT)){
Serial.print("Right held this hard: ");
Serial.println(ps2x.Analog(PSAB_PAD_RIGHT), DEC);
digitalWrite(dir_2,LOW);
analogWrite(pwm_2,50);
delay(200);
if(ps2x.Button(PSB_PAD_LEFT)){
Serial.print("LEFT held this hard: ");
Serial.println(ps2x.Analog(PSAB_PAD_LEFT), DEC);
digitalWrite(dir_1,LOW);
analogWrite(pwm_1,50);
delay(200);
if(ps2x.Button(PSB_PAD_DOWN)){
Serial.print("DOWN held this hard: ");
Serial.println(ps2x.Analog(PSAB_PAD_DOWN), DEC);
vibrate = ps2x.Analog(PSAB_BLUE); //this will set the large motor vibrate speed based on
//how hard you press the blue (X) button
if (ps2x.NewButtonState()) //will be TRUE if any button changes state (on to off, or off to on)
if(ps2x.Button(PSB_L3))
Serial.println("L3 pressed");
if(ps2x.Button(PSB_R3))
Serial.println("R3 pressed");
if(ps2x.Button(PSB_L2))
Serial.println("L2 pressed");
if(ps2x.Button(PSB_R2))
Serial.println("R2 pressed");
if(ps2x.Button(PSB_GREEN))
Serial.println("Triangle pressed");
if(ps2x.Button(PSB_TRIANGLE)) { //forward
Serial.println("Circle just pressed");
for(pos = 170; pos>=10; pos-=1) // goes from 180 degrees to 0 degrees
myservo1.write(pos); // tell servo to go to position in variable 'pos'
delay(30);
for(pos = 10; pos < 170; pos += 1)
myservo2.write(pos);
delay(30); // waits 15ms for the servo to reach the position
if(ps2x.Button(PSB_BLUE)) { //reverse
Serial.println("X just released");
for(pos = 10; pos < 170; pos += 1) // goes from 0 degrees to 180 degrees
// in steps of 1 degree
delay(30);
if(ps2x.Button(PSB_PINK)) { //RIGHT
Serial.println("Square just changed");
delay(200);
if(ps2x.Button(PSB_RED)){ //LEFT
Serial.println("Circle pressed");
delay(200);
if(ps2x.Button(PSB_L1) || ps2x.Button(PSB_R1)) // print stick values if either is TRUE
Serial.print("Stick Values:");
Serial.print(ps2x.Analog(PSS_LY), DEC); //Left stick, Y axis. Other options: LX, RY, RX
Serial.print(",");
Serial.print(ps2x.Analog(PSS_LX), DEC);
Serial.print(",");
Serial.print(ps2x.Analog(PSS_RY), DEC);
Serial.print(",");
Serial.println(ps2x.Analog(PSS_RX), DEC);
delay(50);
Mon Nov 03, 2014 4:26 pm
by roymeyismail
i'm followed PWM Single Channel,Sign-Magnitud Mode setup for each motor through SmartDrive40 Quick Start Guide
Mon Nov 03, 2014 10:11 pm
by ober
I think you should do try out the control of Smartdrive from Arduino mega, develop program to verify the working condition only, combining all the program will actually make the whole project difficult to be debug.
