Advanced Auto-Calibrating Line Sensor_SLA08
Re: Advanced Auto-Calibrating Line Sensor_SLA08
Postby ober » Thu May 12, 2016 11:02 am
Have you check the data from LSA using computer?
Postby Kalman » Thu May 12, 2016 1:58 pm
The data from LSA08 to computer is correct.
Kalman
Postby ober » Thu May 12, 2016 5:16 pm
If the data from LSA08 to computer is correct, then it will be the program on STM, right?
Postby Kalman » Fri May 13, 2016 1:32 am
Yes, I think the LSA08 is working fine. So, I will try to troubleshoot my coding. Thanks for your advice.
Kalman
Postby ober » Fri May 13, 2016 8:32 am
I believe the bugs is in the printf function. Try playing with that.
Postby Kalman » Sat May 14, 2016 8:16 am
The problem had been solved last night, it is due to I didn't connect both STM32 and LSA08 to common ground. Thanks for your help. :)
Kalman
Postby ober » Sun May 15, 2016 10:32 pm
Good to hear that, do share the actual hardware setup photo :)
