Idris WROTE:Hi Flaredro,
Based on your description, I think 10Amp DC Motor Driver is the most suitable. If you need 2 channels, you can consider using Dual Channel 10A DC Motor Driver.
Thank you.
Flaredro WROTE:If I'm using the 10Amp DC Motor Driver, do I still need to apply a 12V to the motor driver or just directly connect to the microcontroller board?
Flaredro WROTE:I do have another stepper motor bought from cytron, is this motor driver suitable for that stepper motor? or L293D is enough to run the motor?
